1. cdf3's Avatar
    I came across a mobile phone stand that works great with my Note 2.
    Got this one from eBay.
    I like it because it has rubber contacts at the bottom, to keep the stand from sliding around on a table. It also has rubber contacts where the phone sits on the stand. I like how the stand folds flat, and the incline level can be adjusted.
    I use it with the Samsung flip cover. I have the hinged part of the cover sitting on the stand. This way the phone is not resting on the power button.
    http://rover.ebay.com/rover/1/711-53...2F121042443153
    Sent from my Samsung Galaxy Note 2
    Attached Thumbnails Mobile phone stand for the Note 2-uploadfromtaptalk1362086874990.jpg
    rankar7, Jude526, dpham00 and 1 others like this.
    02-28-2013 04:28 PM
  2. rankar7's Avatar
    that's pretty nice. thanks for sharing. just pair that with a startech right angle micro-usb cable and you're all set.
    02-28-2013 04:45 PM
  3. zmann's Avatar
    This is a very nice stand that's easy to carry around. Best part is its also a spare battery charger.
    Note 2, it's true, ,size is everything!
    Attached Thumbnails Mobile phone stand for the Note 2-uploadfromtaptalk1362091225385.jpg
    02-28-2013 05:41 PM
  4. zmann's Avatar
    sorry, would not let me put 2 photos in my last for some reason.
    02-28-2013 05:43 PM
  5. cdf3's Avatar
    I have this one as well. I don't use it much because if I flip the Samsung Flip Cover back, it doesn't sit in the stand (volume rocker side sitting in the stand). I have to sit it on the side where the power button is. If I don't let it hang off to the right side of the case, the phone will keep turning off whenever the power button is touched.
    03-01-2013 07:32 PM
  1. Pop Up Play for the Note
    By DAS in forum AT&T Galaxy Note
    Last Post: 11-18-2012, 06:58 PM
  2. Running Armband & Case for the Note
    Last Post: 08-27-2012, 05:01 PM
  3. Is there a non-slip adhesive cover for the Note?
    By cloudcover in forum Samsung Galaxy Note
    Last Post: 06-22-2012, 08:49 PM
  4. Body Glove phone cover for the Merge
    By jtowndawg in forum US Cellular Merge Accessories
    Last Post: 09-28-2011, 05:22 PM
  5. Replies: 17
    Last Post: 10-18-2010, 09:51 AM
