1. AZBrowncoat's Avatar
    I'm having an issue with my GN 2 not detecting my wireless 'N' network...it's finding my wireless 'G' network just fine and all my other devices can see my 'N' network.
    Using a Netgear WNDR 3300.
    Is there a setting I'm missing on the GN 2?
    03-10-2013 08:37 PM
  2. planoman's Avatar
    Mine is picking up and connecting to my N wireless router without any issue. It detects both bands as well. Have you tried a restart of phone and router?
    03-10-2013 09:34 PM
  3. DaRkL3AD3R's Avatar
    I'll bet you almost anything that you're connecting to either a 2.4Ghz Wireless-N SSID or you're connecting to a 5.0Ghz Wireless-A SSID.
    03-10-2013 10:00 PM
  4. AZBrowncoat's Avatar
    Restarted phone and router + changed settings to strict 2.4Ghz from 2.4+5.0 to see if that helps.
    Running speedtest to see what kind of speeds I'm getting now.
    03-10-2013 10:40 PM
  5. Kevin Corcoran's Avatar
    I HAVE A POTENTIAL FIX FOR YOU
    I've been searching forums where people are having the same issue, and pasting my directions below. I had the same damn disgusting issue!!
    ATTENTION! Jelly bean 4.2.1 BREAKS WIFI on Galaxy Note 2 ! DOn't install it!
    If you already installed it, and your wifi is broke. Install these two very popular programs below. They fix the wifi. Don't ask me why, but it worked for us. I found it on another forum.
    Wifi Analyser
    https://play.google.com/store/apps/d...5hbmFseXplciJd
    Wifi Connecter Library
    https://play.google.com/store/apps/d...29ubmVjdGVyIl0.
    06-03-2013 09:20 AM
  6. DaRkL3AD3R's Avatar
    Wifi Analyser
    Thanks for the update on this. When you say 4.2.1 breaks Wifi, you mean like if I flashed a ROM that is 4.2.1+ and went back to 4.1.x it will still be broken? Just curious. Especially since the Galaxy Note 2 doesn't officially have 4.2.2 yet.
    06-04-2013 09:12 PM
  1. rooted andriod wireless tether laptop won't connect to internet
    By redmonde in forum AT&T Samsung Infuse
    Last Post: 04-18-2012, 08:22 AM
  2. Wireless Tether App - Laptop Won't connect!
    By zeth006 in forum Samsung Intercept
    Last Post: 01-03-2011, 11:12 AM
  3. Wireless Tether for Root Won't Connect
    By geoandroiddaddy in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 11-13-2010, 03:51 PM
  4. Wireless tether won't connect to mac
    By stormaddict13 in forum Software Development and Hacking
    Last Post: 08-13-2010, 11:03 AM
  5. Setting up VPN to connect to home computer? Please help.
    By spierce7 in forum Motorola Droid
    Last Post: 01-11-2010, 02:28 AM
