1. Andre2001's Avatar
    Hi,
    The Internal memory on my phone is full.So I tried to delete so media/photos went into gallery however I get the message to delete photos and media. I cleared the cache on all applications but still no joy.
    Then I downloaded Kies 1st on the mac osx Lion, I tried to connect and It would not recognize the device so I go into my windows 7 machine and install Kies again, still nothing.
    The only thing that happens when I use the USB is it charges, the notification gives me no other options, Debug mode is selected tried all the usual tricks taking battery out ect.
    I'm stuck as I cannot delete the photos on the phone and cannot do it through usb as mass storage as osx or win 7 will not recognise the device..
    Any Ideas?
    Just a quick update I tried using my wife's note 2 and all works fine. Just on my note 2 It simply will not connect to Kies or my computer and only charges. I also tried other usb cables
    Andrew
    03-29-2013 11:29 AM
  2. aquafusiondane's Avatar
    Note 2 come with a file explorer app which Samsung provided, it called "My Files". Use that app to delete the pictures. Opening My Files app, click image and it will show you a list of folders that have images in it. Click one of those folder and try to delete the pictures that you don't need
    Sent from my T-Mobile Samsung Galaxy Note 2 on Tapatalk 2
    mmtrevor likes this.
    03-29-2013 01:53 PM
  3. Andre2001's Avatar
    Thanks for the info. It solved the memory issue so I appreciate the reply.
    Still need to find out what is causing the phone not to be recognized as a storage device so will try some additional steps.
    Thanks again
    Andrew
    03-29-2013 11:47 PM
  1. Memory Card Problem
    By movieman742 in forum Motorola Droid X
    Last Post: 10-11-2011, 09:39 PM
  2. After Failed Fennec Install, Memory Full?
    By TxDoc in forum Android Apps
    Last Post: 09-26-2011, 04:06 PM
  3. text message memory full??
    By emdee81 in forum Motorola Droid
    Last Post: 03-18-2011, 05:24 PM
  4. Text Messaging Memory? Full?
    By jacob.downey in forum Google / HTC Nexus One
    Last Post: 12-13-2010, 05:50 PM
  5. Memory card problem
    By droidluvr in forum General Help and How To
    Last Post: 08-16-2010, 12:41 PM
