1. jodyberry's Avatar
    I really like the griptight gorillapod but the jaws aren't wide enough to fit our Note 2. I think their max is 2.8 inches.
    GripTight GorillaPod for iPhone, Android & Windows Smartphones
    Does anyone know of something similar to be able to secure the phone when taking photos, etc? I'm not talking about a car mount, but more of something that can attach to most irregular surfaces (like the gorillapod does).
    Any ideas would be greatly appreciated!!
    03-29-2013 03:50 PM
  2. jodyberry's Avatar
    UPDATE:
    OK, I just got this email from GorillaPod:
    We do not have a solution currently for the Note 2.
    Well contact you if we introduce a larger version of the Grip Tight soon.
    So then, does anyone have a similar solution?
    Thanks all...
    03-29-2013 03:58 PM
  3. jodyberry's Avatar
    So I ordered a few cheap versions from China and will see how they work once I get them.
    I also fabricated a unit of my own from some spare parts on my workbench. It doesn't look as slick as the store-bought ones but it definitely does the trick!!
    Sent from my Samung "Brick"
    04-01-2013 11:37 AM
  1. I am going crazy - where to get wallpaper that actually fits my Nexus 7
    By Traveler5 in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-01-2013, 12:10 AM
  2. ??best belt holster that will fit a evo3d with silicon/gel cover
    By u71n4444 in forum HTC EVO 3D Accessories
    Last Post: 07-31-2011, 07:37 PM
  3. Any cases that will fit with extended battery?
    By splmonster in forum EVO Accessories
    Last Post: 11-20-2010, 05:16 PM
  4. Caring cases that will fit the EVO....
    By mrgregory29 in forum EVO Accessories
    Last Post: 07-25-2010, 08:30 AM
  5. Case that will fit with Extended Battery
    By Doc in forum EVO Accessories
    Last Post: 07-12-2010, 01:02 PM
