04-05-2013 04:05 PM
29 12
tools
  1. outlooker's Avatar
    I'm switching over to Android and I'm considering getting the Note 2, but I have a few simple queries I hope someone wouldn't mind answering:
    1) Is it hard to carry around a Note 2 all the time? I know it's one of the biggest phones out there which makes it something to be concerned about. In winters you can just put it in your winter jacket but what about in the summer or indoor environments? I usually dress a bit formally, generally regular adult sized dress pants. Would the Note 2 fit in dress pant pockets? It would easily fit in a suit jacket or a blazer but I often don't wear one. Carrying it around probably isn't the safest option as you could drop it or even worse get it stolen.
    2) Gaming Performance? Do games run on the huge 5.5 inch screen properly? I want to be able to run absolutely ANY game available on the Play Store easily without lag.
    3) Does the At&t Note 2 have a MicroSD card slot?
    4) How much memory does it have, 32 or 64GB?
    5) How long does the battery last, with about 1-2 hours of gaming, and one hour of internet browsing? (I hardly ever talk on my phone)
    Thanks in advance!
    03-30-2013 05:03 AM
  2. jdub1981's Avatar
    Gaming is what will drain the battery most. Real racing 3. Which is a very graphical game runs with zero lag and fast load times. Low graphic games like angry birds or wheres my water are considerably less battery intenssive. Mileage may very is the best advice I can give in these regards. My att note 2 with case fits comfortably in my jeans front pocket. I am 6 foot tall and I dont where skinny jeans. Unfortunately they only sell 16gb phone in the states. But I have a 64gb memory card that I store my movies pictures and music on and with 60 or so apps on my phone I still have 8gb internal memory left.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    03-30-2013 07:24 AM
  3. Rickgsx's Avatar
    Thanks in advance!
    I would suggest going on YouTube and do a search on "Galaxy Note 2 Review", Battery review, etc... There is where I acquired most of my information that help me make the decision. As for the battery, the BEST battery life todate was 1 day/9 hours/31 mins ON Battery with 12% left...
    Hope this helps...
    karsdroid likes this.
    03-30-2013 07:56 AM
  4. imarek3's Avatar
    Yes, the Note 2 is big and going try one out at a store and see if you feel like you can live with it. I have only had the Note 2 for 2 months, but now when I use my wife's Galaxy S3, it seems absolutely small. I have not had any problems with games on the Note 2 or the battery lasting through out the day.
    Good luck on your decision.
    03-30-2013 09:05 AM
  5. Chocu1a's Avatar
    Thanks in advance!
    1) I am 6' tall & medium build, wear levi 501 jeans that fit. I mean, not loose, not tight. Fits fine in front pocket, easy in, easy out.
    2) Haven't found a game that lags. I play Shadowgun, Dead Trigger, NBA Jam, Real Racing 3 & NFS MW.
    3) All Note 2 have micro sd.
    4)16gb in the States. I have 110 apps installed, 6.62 gbs free.
    5) Best battery I have had was 2days, 4hrs, ,with 5 & 1/2 hours screen time. I average 14-16 hours with at least 30% at end of day with medium/heavy usage.
    03-30-2013 10:25 AM
  6. Tony2255's Avatar
    1. Without a case it fits in my pocket fine. When I put it in my otter box I have to wear it on my belt.
    2. Great for games
    3, yes
    4. 16 but I put a 32 gig card in
    5. Very heavy use I get 12-16 hours. Great battery...best in industry for sure although my Z10 comes close.
    You will love th note if you like Androids
    03-30-2013 10:45 AM
  7. universeand's Avatar
    With a Cruzerlite A2 gel case, the Note 2 fits in the front pockets of my men's dress slacks with plenty of room to spare. I can easily slip it in and pull it out. That's the way I carry my Note around the workplace.
    Ridin' a Note 2 blast
    03-30-2013 11:29 AM
  8. jneusch's Avatar
    I carry mine in the pocket of my dress pants or the breast pocket of my suit jacket. Either is very comfortable. I prefer the pants pocket though. The phone is big enough that it doesn't shift to the side, it stays standing while in my pocket.
    It also fits fine in jeans pockets and shorts pockets. I had it with me 2 entire days at Sea World and Busch Gardens during spring break.
    The battery should last all day unless you are going crazy with it.
    Sent from my SCH-I605 using Android Central Forums
    03-30-2013 07:06 PM
  9. iso99's Avatar
    I am comfortable putting it in my front pocket too, with a flip cover.
    Battery is good. Will last a day even with heavy data usage.
    03-31-2013 11:01 AM
  10. kkapoorr's Avatar
    What about sd cards? Which class and storage do you all use? I need to buy one...
    Sent from my GT-N7100 using Tapatalk 2
    03-31-2013 11:08 AM
  11. Jude526's Avatar
    I love this phone. Best ever. Battery life is great. I never have to worry
    Sent from my Samsung Galaxy Note2
    03-31-2013 11:14 AM
  12. zmann's Avatar
    I use very thin cases and it fits great in any pocket of my jeans. I use a 30 gig class 10 card and it has worked flawlessly.
    Note 2, it's true, ,size is everything!
    03-31-2013 12:47 PM
  13. kkapoorr's Avatar
    What brand? And what price?
    03-31-2013 12:50 PM
  14. Tony2255's Avatar
    I have a 32 gig class 10. Works great.
    Sent from my Z10 using Tapatalk 2
    04-02-2013 02:55 PM
  15. Lastnv's Avatar
    1) I have the UAG case on mine which is kind of thick but it fits in my pants and I wear slim jeans. It's a little bit of a struggle sometimes to pull out but it does fit in my pocket securely with the one corn usually sticking out a little though.
    2) Flawless gaming performance. I don't play real big graphic intensive games but it plays games like Dead Trigger perfect. Games look GORGEOUS on the Note 2. You would think that the big screen size would stretch the graphics or something but it doesn't, or at least not on any games I have encountered.
    3) Yes every model of the Note 2 does.
    4) 16gb built in. I have a 64gb class 10 sandisk in mine and haven't had any problems, been using it for 2 months now. I have heard of people having issues with the 32 and 64 before though.
    5) I use my phone for a lot of web browsing on Chrome, Facebook app, and about 2-3 hours of games and it usually gets me through the day with 20% left. It's hard to pinpoint how exactly long it will last but if you're fully charged at the beginning of the day you're guaranteed to get through the day.
    04-02-2013 03:29 PM
  16. So Cold's Avatar
    I wouldn't make general statements like that. For the ops intended usage the phone should last all day no problem, however the battery can certainly be killed in less than day by heavy usage. It's a fantastic phone with a fantastic battery but that's just a fact
    Sent from my Note 2
    04-02-2013 05:07 PM
  17. Jude526's Avatar
    Sent from my Note 2
    Exactly. Everyone's use is different. I can end the day at 71% or as low as 40% all depends on use. But I will admit I haven't had to worry about charging it during the day.
    04-02-2013 05:36 PM
  18. So Cold's Avatar
    And I've had days where I can drain the battery by 6pm. I wouldn't call that normal by any stretch but it certainly can be done
    Sent from my Note 2
    04-02-2013 05:45 PM
  19. Tony2255's Avatar
    Depends on your use. Most days mine would get me the full day others half the day. For the past few years I just carry a charger around with me to make sure I always have juice no matter what phone I am using.
    04-02-2013 09:41 PM
  20. kkapoorr's Avatar
    Are any of your games/game data saved on the sd card? Does saving on sd card affect the performance?
    04-02-2013 10:27 PM
  21. brentj's Avatar
    The phone fits fine in my front pants pocket, jeans or dress pants.
    I use a SanDisk Class 10 64Gb card, now $55 at Amazon (I think I got mine on sale for around $46): Amazon.com: SanDisk Ultra 64 GB MicroSDXC Class 10 UHS-1 Memory Card with Adapter (SDSDQU-064G-AFFP-A): Electronics I've read several posts of people having problems with the 32GB size, but I've had no problems with the 64.
    My understanding is that apps cannot be installed to the external SD card. Whether app data could be stored there I don't know, it may depend on the app. I've set the camera to store photos on the external card.
    04-02-2013 10:38 PM
  22. So Cold's Avatar
    Same here. I have a 64gb card and I have no issues with it
    Sent from my Note 2
    04-02-2013 11:11 PM
  23. Tony2255's Avatar
    Sorry don't game much so I couldn't say.
    kkapoorr likes this.
    04-03-2013 05:10 AM
  24. Shanghaichica1's Avatar
    I'm not a note 2 owner, I have the galaxy note 1. I have several of my games stored on my SD card and they play just fine. I don't play intense games, just things like angry birds, world of goo, plants vs zombies, tetris etc.
    Sent from my Galaxy Note using Android Central forums
    04-03-2013 05:22 AM
  25. jdub1981's Avatar
    Some games can be played from the sd card. They just have to be coded to do so. An example of this is the game " A Bards Tale" that game is 2gb in size and after the initial small download in the playstore you are greated with an option to download an additional 2gb with the option to save to external sd card.
    04-03-2013 07:20 AM
29 12
  1. Replies: 2
    Last Post: 02-09-2013, 10:07 AM
  2. Note 2 New Owner Here - Need Some Help
    By notedesigner in forum Samsung Galaxy Note 2
    Last Post: 01-30-2013, 09:29 AM
  3. Need some help from Rezound owners
    By tayswg20 in forum Verizon HTC Rezound
    Last Post: 06-02-2012, 12:57 AM
  4. First impressions from G-Note owners?
    By kharrigan in forum Samsung Galaxy Note
    Last Post: 12-22-2011, 05:10 AM
  5. Phone pseudo bricked - really need some help (hopefully from thefredelement)
    By hgelpke in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-31-2011, 06:05 PM
