1. jdub1981's Avatar
    Was watching lucidmike the other day and he was using a simple widget called application monitor. I found it in the samsung appstore and upon installing I found it to be a crazy simple app. It basically a external task manager monitor that reads cpu usage. When it turns red something in the background is chewing up cpu time ie. Battery life.
    A simple click on takes you to the task manager so you can manually close the app. Some apps idle at 0% while others will continually eat power even while suspended, this lets you know fairly simple whats bad and whats good.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    04-09-2013 03:39 PM
  1. Simple battery and signal widget
    By admsteck in forum Android Apps
    Last Post: 09-30-2010, 07:26 AM
  2. Can anyone identify this battery widget?
    By nightranger in forum Android Apps
    Last Post: 08-14-2010, 11:05 AM
  3. Looking for a specific battery widget
    By malhotra365 in forum HTC EVO 4G
    Last Post: 07-02-2010, 11:56 AM
  4. Which Battery Widget do you prefer?
    By mattmcg in forum HTC EVO 4G
    Last Post: 06-20-2010, 01:53 AM
  5. why isnt the battery widget unaccurate?
    By alextrox69 in forum HTC EVO 4G
    Last Post: 06-07-2010, 11:03 AM
