The battery is kinda awesome really.
I'm just always on the hunt for new technology. But the main reason is because Google Services has been killing my battery.
It seems that the Google Services battery drain issue started around the Google I/O and if I don't restart my Note 2 before charging it I get even worse battery drain from Google Services.
I just hope Google fixes this soon as this is an issue with them alone. It's not just a Note 2 issue. The S4 and S3 as well as Nexus devices have this issue.
I just can't deal with this for much longer. It suck's that I have to restart my Note 2 every charge and within an hour of my Note 2 just sitting there Google Services is at the top of my battery list in settings. Android OS will be at about 16% then Google Services will be around 45% at the very top of the list. That's bad very bad...
Please Google fix this!
Sent from my SGH-T889 using Tapatalk 4 Beta
Google play music is a constant load on your cpu. Even if you kill the process it will automatically restart itself. I uninstalled the update and disabled mine. Also go to google settings app and turn off the option to report from this location options. Battery should go back to normal. Hopefully updated apps come out soon.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
