01-22-2016 02:11 AM
30 12
tools
  1. bigdogburger's Avatar
    Thanks!!! That sensor cleaning thing helped!!!
    07-30-2015 10:37 PM
  2. Bruce Righter's Avatar
    I've been tearing my hair out trying to figure out a similar problem. When I got a call, I'd hear a ringtone but couldn't find the usual red/ green icon on the screen (i.e. I couldn't answer). The caller would leave a voicemail. I could call the VM, but never had the usual red bar icon to hangup.
    I've read various hints, but none worked. Read one about deleting my phone data, but that was too scary.
    A youtube suggested turning off "Automatic date & time" under settings, and it seems to have worked. I made one call and received one & all was normal.
    Probably not a universal fix, but it seems harmless to try??
    08-29-2015 11:09 AM
  3. keshiv12's Avatar
    My Note 2 has a serious problem! I can't hang up on calls.
    I dial a number and lets say I want to hang up before the call goes to VM -or the conversation is over and I want to hang up. Usually I take the phone away from my ear, the screen lights up and the option to end the call is displayed. No longer... Now the screen remains black, I can't hang up, and the home button and power button do NOTHING. I have to take the battery out of my phone to hang up or get any sort of response from the phone.
    HELP! this is driving me nuts."Motion" is turned on. Don't know if that is doing anything.
    Stock Verizon set-up, 4.1.2 JB.
    You can put earphones in the phone while on a call and it should wake up
    liachang126 likes this.
    10-18-2015 05:32 AM
  4. Edi Manquehue's Avatar
    I had that problem for years. After trying several apps, I solved that problem installing the free app "AutoScreen OnOff"
    My Phone: THL T11
    01-22-2016 02:03 AM
  5. Edi Manquehue's Avatar
    I 'm sorry, I don't know how to delete a post here.
    01-22-2016 02:11 AM
30 12
  1. Hung Up On Flashing
    By barathan.n in forum Samsung Galaxy Note
    Last Post: 06-14-2012, 06:24 AM
  2. [HELP] Can't flash RebornROM on my Optimus V :(
    By cotylee1991 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 12-01-2011, 04:59 PM
  3. Hangs up on calls constantly
    By popkurn611 in forum Misc. Android Phones
    Last Post: 10-08-2011, 01:13 AM
  4. Need help. Can't turn phone on. Tried TELUS sticky from XDA on fascinate.
    By epik151 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 02-25-2011, 03:57 AM
  5. 3 way and call waiting Can't hang up on 1 pers Incredible
    By jamesy in forum Verizon Droid Incredible
    Last Post: 06-26-2010, 03:35 PM
