I am a fairly new Note 2 user, and I am using it for quite a bit of HD video viewing and with the need to store my movies on the SD card, I tried to put in a 32gb. I was not having issues with the 16gb I put in, until it got full! So, I 'Unmounted' the 16gb, pulled it, took the folders off it and put them on the 32gb using my laptop, then put the 32 gb in the phone. It still showed that it was a 16gb! So I rebooted the phone, tried un-mounting and re-mounting again. STILL showing a storage space on the card of 16gb total. WTF is the deal??? Anyone know how to get this thing to read correctly so I can store my video files?
Two other issues I am having that are minor, have to do with the lock screen.
1. Whenever I have to 'Swipe to Unlock', and I do so, and it shows the silly high-graphic 'ripple effect', I have to repeat this swipe motion on the screen 2-3 times before it will open the screen.
2. Does anyone know how to change the apps at the base of the Lock Screen, or better yet, remove them completely? It shows the default 'Phone', 'Mssg', 'Google', 'Email', and 'Cam', but I would like to remove them from the lock screen or at least change them like I can easily do on the home screens. It will not allow me to press and hold to move them. Any ideas?
While I am at it, if anyone happens to know, are there any compatible longer-lasting batteries for the Note 2 that do NOT require you to have a huge bulky replacement back cover? If not, what is the best battery set-up of any kind to put in the phone for long-time use and video watching?
THANKS GUYS, YOU ROCK!! xoxoxo
