1. karsdroid's Avatar
    is there a way to change the s pen removal sound? ok let me clarify, i know how to change to the 3 different sounds but is there a way to set my own?
    05-11-2013 03:10 PM
  2. nightelfdruid's Avatar
    S-pen helper and S-pen toolbox do it without root. Toolbox is paticularly nice. If you'd like, it will display a small window with the apps of your choosing when you remove the pen as well.
    Sented from the Galuksee Noat Tew.
    karsdroid and BKlip like this.
    05-11-2013 04:49 PM
  3. Evo4g's Avatar
    Yes, right now I am using the light saber sound
    First download the S Pen Helper App from the market.
    Once downloaded enable S Pen Helper then scroll down and enable detachment sound. ( note do this with the SPen itself)
    Select detachment sound.... it will then go to your storage
    select the audio file (must be mp3 and cannot be to long of a clip)
    Also make sure you turn off detachment sound under S Pen settings or you will get two sounds
    05-11-2013 05:02 PM
  4. jdub1981's Avatar
    I posted the original post for the lightsaber removal and insertion sound way back in November. Instructions for downloading the sounds are included in the post. Search for it in the galaxy note 2 rootsection
    Sent from my Galaxy Note 8.0 using Tapatalk
    snkycool likes this.
    05-11-2013 06:25 PM
  5. karsdroid's Avatar
    thanks everyone.....spen toolbox works great!
    05-11-2013 08:29 PM
  1. Replies: 11
    Last Post: 04-07-2013, 03:11 PM
  2. S-Pen removal: only option is to launch a pop-up note??
    By fgkay in forum Sprint Galaxy Note 2
    Last Post: 11-30-2012, 11:23 AM
  3. Is There Anyway To Change The Screen Selection Sound
    By TrendyProfessional1 in forum Verizon Galaxy S III
    Last Post: 07-18-2012, 05:13 PM
  4. Anyway to change the water droplet sound when making a phone call
    By elvis1935 in forum Sprint Galaxy S III
    Last Post: 07-07-2012, 10:36 PM
  5. Changing the default keypress sound?
    By j0cular in forum HTC EVO 4G
    Last Post: 11-01-2011, 08:38 PM
