12-20-2013 04:14 AM
88 ... 234
tools
  1. mumfoau's Avatar
    I have everything switched on gps bluetooth wifi and data i have refresh rates set to minimum on everything i use fb watch videos and use other apps for around 3 hours a day on and off also have widgets and other apps running and my battery lasts from 6.30 till aroudmd 11pm which is when it goes back on charge tbh i think that is good for the screen size
    sent from my note 2 rooted on 4.4 kitkat
    If 3 hours is to be my screen on target then I should able to hit that pretty easily!
    12-16-2013 04:27 PM
  2. mumfoau's Avatar
    Made it through an entire day without charging...
    Sent from my Galaxy Note II using Tapatalk
    Attached Thumbnails Need help with Note 2 battery!-uploadfromtaptalk1387246779599.jpg   Need help with Note 2 battery!-uploadfromtaptalk1387246799796.jpg
    mrsmumbles likes this.
    12-16-2013 08:20 PM
  3. mrsmumbles's Avatar
    Hey, that's not bad! :thumbup: I'm glad this is working out better now!
    Sent from my Nexus 5 using Tapatalk 2
    12-16-2013 08:57 PM
  4. mumfoau's Avatar
    Sitting at 82% after 6 hours, 44 minutes! That puts me on pace to reach 30 hours before I get the 19% low battery notification!
    12-17-2013 11:57 AM
  5. sheffsteve1988's Avatar
    I am pretty happy with battery and use age
    Attached Thumbnails Need help with Note 2 battery!-1387304292559.jpg   Need help with Note 2 battery!-1387304304225.jpg   Need help with Note 2 battery!-1387304319650.jpg
    12-17-2013 12:19 PM
  6. mumfoau's Avatar
    15 hours, 45 minutes today with 3 hours, 30 minutes screen on time! Still have 27 percent remaining!
    12-17-2013 08:57 PM
  7. newbroot83's Avatar
    3 days 19 hours and 27 minutes with 6 hrs screen time. Still at 40%. Love my extended battery
    Sent from my SCH-I605 using Tapatalk
    12-17-2013 09:14 PM
  8. mumfoau's Avatar
    Extended battery? Hmm... Tomorrow, I switch off power saving and full throttle for the day. Had power saving on the last couple days
    12-17-2013 09:28 PM
  9. newbroot83's Avatar
    Zero lemon 9300 mah. 45 dollars on amazon. Money well spent. 4 to 5 days without chargind is nice. And im in an atrocious signal area. This battery is exactly triple the size of the stock battery
    12-17-2013 09:54 PM
  10. jdub1981's Avatar
    To all those with battery issues. Ive had this phone for 1 year and 1 month. A few lessons on battery life to get you through it all.
    1. 99% chance it is an app or OS function that is draining your battery and nothing is wrong.
    2. Google plus and google now, atleast for me are the devil. They are constantly requesting background location data inorder to give me unrequested data.
    3. Settings...wifi...menubutton...advanced. toggle option keep wifi on during sleep to only when plugged in. Sleep does not take place as soon as the screen turns off. If app such as the playstore is currently downloading then it will continue with the screen off. Once everything is finished in the background then sleep occurs and wifi turns off.
    4. Depending on your carrier there is a long numerical code that can be entered into the dialer that will enter you into a test mode. In this mode there is many built in options than can test every aspect and reports current status...battery is one such test.
    5. I see alot of screens here that are showin screen time with android os and other android functions. If you touch these apps you are presented with many functions of the os that are currently in use. Some are easy to understand others are not if any pop out at you is something you want to know more about google it. You will learn alot.
    6. Auto sync is the devil. Make sure that your pictures and videos are not to autosync to their individual apps unless on wifi and plugged I .
    5 years as an iphone lover this was my first android. Lots to love, you just need to get to know the quirks of an OS that gives the user total control. On average I get 1.3 days on single charge. I still charge everynight though cuz you just never know.
    Ill be editting this post to submit more info shortly.
    Here is the code list link. Along with pictures of what is provided in test mode. http://forum.xda-developers.com/show....php?t=1520115
    Sent from my GT-N5110 using Tapatalk 4
    12-18-2013 01:47 AM
  11. mumfoau's Avatar
    Thanks for the info jdub! I think my main issue was signal and that my phone was trying to get to LTE in an area at work where that wasn't possible! As side load of phone info allowed me to toggle that off and problem solved! For the last 2 days I've gone from early morning to bed time on a single, overnight while powered off charge! I do use auto-sync. Can you confirm if any of those codes work for verizon? I've tried some before came away with nothing!
    Sent from my iPad using Tapatalk HD
    12-18-2013 04:26 AM
  12. jdub1981's Avatar
    No I cant confirm or deny anything for verizon as I use ATT. However it easy to test, start at the top of the list open the dialer and input the code upon pressing the last digit if the code works you be automatically taken to the test menu or whatever the code relates to. Becareful though, if you get to a page with random clickable/changeable settings be cautios because changing something here can jack your phone up.
    Side note. One of these codes will take you to a menu that lets you legitimately unlock your phone for other carriers.
    Sent from my Galaxy Note 2
    12-18-2013 01:54 PM
  13. morph000's Avatar
    Hmmm. I tested mine last night. 100% charge and stopped using it at 9pm. I also have Nights Keeper installed which shuts down non essentials except GPS (which it can't control, nor can anything else BTW). Checked it at 9am when Nights Keeper switches off, and battery was down to 93%. Not bad for 12 hours eh !
    I also run reduced screen brightness, 15 sec turn off when inactive, disable unwanted email syncing and other dross..
    12-20-2013 04:14 AM
88 ... 234
  1. Really need help with Note after ICS upgrade
    By Luv_Note in forum Samsung Galaxy Note
    Last Post: 12-11-2012, 05:26 AM
  2. Need help with Trexcell Extended battery and replacment cover
    By kziegelmeyer in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 03-05-2012, 03:19 PM
  3. need help with battery savings
    By dhallett12 in forum LG Optimus 3D
    Last Post: 02-17-2012, 11:49 AM
  4. Need help with battery drain issue
    By rhittle in forum AT&T Samsung Infuse
    Last Post: 07-17-2011, 06:45 PM
  5. Need help with battery drain issue
    Last Post: 07-12-2011, 05:39 PM
