1. kollygreen's Avatar
    Hi There,
    I have a Samsung Galaxy Note 2 and I have a VPN connecting the phone to my office IP PBX. When i enable the VPN and use the soft phone to make a call the call hangs up after a minute exact. I used another client and the same thing happened. I even tried to adjust the VPN and the wireless settings and the same still happens. I welcome any assistance. Thanks.
    05-14-2013 06:40 PM
  2. rankar7's Avatar
    Hi There,
    this doesn't sound like an issue with your note2. i would check with your pbx administrator because it sounds like a limit has been enabled associated with your location (soft phone). also check to make sure that the feature is enabled over you wireless network. a number of providers (like the cisco voip) do not recommend using their soft phone over a wireless network.
    05-14-2013 11:30 PM
  1. Dropped calls after 4.2.2?
    By wwu123 in forum Google Nexus 4
    Last Post: 06-03-2013, 05:30 AM
  2. Sprint GS3 drop calls after 4.1 upgrade
    By droid_4_life in forum Sprint Galaxy S III
    Last Post: 02-05-2013, 09:05 PM
  3. Evo keeps dropping calls after exactly 30 minutes?
    By Devilicus in forum HTC EVO 4G
    Last Post: 07-27-2011, 02:14 PM
  4. Dropped Calls on AT&T with Nexus one??
    By shazo in forum Google / HTC Nexus One
    Last Post: 10-23-2010, 02:23 PM
  5. Anyone else having dropped calls on 07/17 in Northern California?
    By Shenaniguns in forum General Carrier Discussion
    Last Post: 07-17-2010, 11:33 PM
