1. Chin ng's Avatar
    I'm planning to use go launcher as my default homescreen. But before I set the default. I would like to know that how to return back to its original samsung home screen in case im not gonna like the 3rd party home screen apps.
    Can anyone tell me how?
    Thanks
    05-17-2013 09:30 AM
  2. 11DanTheMan11's Avatar
    Hey I use Go launcher as well, and its a good one. Lot of stuff you can do with it in the settings. The stock UI will never go away, so when you uninstall the Go Launcher app it just goes back to normal. Thats how mine was. Check out YouTube for all the things you can do with it, thats how I learned. Peace!
    rrvardeman likes this.
    05-17-2013 10:17 AM
  3. SpookDroid's Avatar
    When you install a 3rd party launcher, whenever you hit the "Home" button a pop-up will appear asking you to select which Launcher to use. It will also ask you to select whether you want to use that app just that one time or all the time (set it as default). If you want to go back after you set something else to default (for instance, say you install GoLauncher, press Home and select "Always"), all you have to do is go to your Settings, Application Manager, find the 3rd party app and select "Clear Defaults". This option restores the pop-up and you can select another launcher when pressing the home button. The same method applies to everything else that can be handled by several apps in your phone (web links, photos, etc.)
    05-17-2013 10:19 AM
  4. 44Stretch's Avatar
    I use Homesmack to switch between different launchers. It allows you to set which one you want as default and switch between different launchers easily without going into settings. It's in the Play Store
    flexfield likes this.
    05-17-2013 03:03 PM
  5. JuanAlpha's Avatar
    This advice (and the one following) have been MOST helpful!!! I called Samsung Technical Support and they advised a few things to help, but nothing did. This advice was much easier to follow, as it does not involve anything close to the dreaded MASTER RESET!!! Big thanks!!!
    44Stretch recommended downloading the HOMESMACK app. I did, and once loaded it gave me an option to reset to default. Voila, I was back to my former Home Theme toggle options!!! Thanks guys!!!!!
    10-30-2013 05:12 PM
  6. Hasbrobot's Avatar
    10-31-2013 05:20 AM
  7. yapleehyun's Avatar
    hi, then how can i stop the pop-up from appearing whenever i press the Home button? it's annoying me...
    12-16-2013 01:05 PM
  8. Andy847's Avatar
    I use Twisted Home Switcher. Only because I use nova Launcher Prime and need to go back to touchwiz to change the lockscreen wallpaper on my phone.
    12-16-2013 04:18 PM
  9. MisssLowry's Avatar
    So I know how to clear the default app settings but when I try to choose a certain one or when I click on always it tells me to go to applications and clear the default settings. This notification pops up for everything I do, Internet, home, pictures, etc. Does anyone know how to do this? Please help!
    07-17-2014 04:57 PM
  10. Ian Patiag's Avatar
    Hi....my problem in note 3 my main luncher or original luncher of note 3 i delet...the big problem is my if i open again my note 3 it will be come bluescreen...can u help me pls tnx
    08-03-2014 09:18 AM
  11. Ian Patiag's Avatar
    how can i fix my note 3 bcoz if im off my cp den i open again it will become bluescreen...plss help
    08-03-2014 09:29 AM
  12. prepaidguy9081's Avatar
    Delete the default in the application area of settings for the app that as the default action for home set.
    Scroll down to see it.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
    08-04-2014 06:54 AM
  13. prepaidguy9081's Avatar
    Boot into download mode
    Flash custom recovery
    Boot into custom recovery
    Wipe data factory reset
    Wipe cache
    Wipe advanced/dalvik cache.
    Install zip from sd card.
    Install a downloaded rom.
    Reboot.
    Fixed
    08-04-2014 06:56 AM
  1. How to get back to Original Home Screen
    By bcball in forum Sprint Epic 4G
    Last Post: 10-23-2017, 03:50 AM
  2. How do I add an app to the home screen?
    By cb2367 in forum Sprint Galaxy S III
    Last Post: 10-03-2012, 11:05 PM
  3. How do you add folders to the home screen?
    By msoprano13 in forum HTC EVO 4G LTE
    Last Post: 07-05-2012, 01:03 AM
  4. How to fix home screen auto orientation switch lag
    By rizaldi in forum Samsung Galaxy Tab 10-inch
    Last Post: 07-31-2011, 08:26 PM
  5. Replies: 2
    Last Post: 06-04-2010, 10:24 AM
