1. stenote's Avatar
    Lately my note 2 has been running slow and lagging alot such my internet browser running slow and the most annoying typing the word and not showing up till a few seconds later which is really annoying me any thing known that causes this or any fix?
    Sent from my SCH-I605 using Android Central Forums
    05-19-2013 01:48 PM
  2. jdub1981's Avatar
    Others may say different but after 6 months mine was doing the same. I read about cache cleaners and apparently our phones contain many different types of caches. Clean Master is supposedly the best new cleaner out, I tried it and it seems like my phone is both faster and my battery lasts ALOT longer.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    05-19-2013 03:21 PM
  3. mmohn01's Avatar
    I use app cache cleaner, but yes it does help prevent lag and extend battery life. Also, I have spare batteries. So, I am literally rebooting my phone at least once a day with a battery pull, as I am a very heavy user due to the business I have.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    05-19-2013 04:33 PM
  4. soulstlr's Avatar
    +1 clean master
    05-19-2013 04:52 PM
  5. stenote's Avatar
    Ive had the clean master for months noe and clean at least 2 times a day.
    I have an extended battery the 9300mah zerolemon battery could this have caused it?
    05-19-2013 05:05 PM
  6. mmohn01's Avatar
    I doubt the battery caused it. The only thing that battery affects is the nfc. You are no longer able to use nfc. Sometimes you phone just needs a battery pull, and when you have a battery that large you sometimes forget to reboot on occasion.
    05-19-2013 08:30 PM
  7. jdub1981's Avatar
    I have the zero lemon as well. It lasts me 4 days easily and thats heavy use. Its not my everyday battery just my long extended trips with no power source battery.
    I doubt its the zero lemon, when you look at your app manager what item uses the most power? Screen shots here will help tremendously.
    Sent from my Galaxy Note 8.0 using Tapatalk
    05-19-2013 09:13 PM
  8. stenote's Avatar
    I get just over 5 days love this battery
    05-19-2013 11:04 PM
  9. stenote's Avatar
    Attached Thumbnails Note 2 running slow-uploadfromtaptalk1369022685110.jpg   Note 2 running slow-uploadfromtaptalk1369022694087.jpg   Note 2 running slow-uploadfromtaptalk1369022702520.jpg
    05-19-2013 11:05 PM
  10. Golfdriver97's Avatar
    Clean master is very good. Clearing cache in rwcovery may help too.
    05-19-2013 11:18 PM
  11. jdub1981's Avatar
    A couple things you might try. One is get rid of the battery saver, you shouldnt need it with the zero lemon any how. If you use clean master, keep on using it. I have mine clean once a week or more if I open it. If you use power saving mode you might try turning it off since it slow down your cpu to conserve power. The battery saver app may do this as well, I dunno. Overall ive had a good experience with my note 2. I have a weird glitch but I do t know if its root related or my phone. I have a alot of bookmarks on stock Internet app and when I open the bookmark section they flash a couple of time before I can press on them. Im not sure how to fix this since I do t know what causes it.
    05-19-2013 11:37 PM
  12. Bekaar's Avatar
    Bookmarks are HORRIBLY SLOW. Samsung needs to fix this.
    08-16-2013 07:31 AM
  1. My EVO running slow
    By dashib in forum HTC EVO 4G
    Last Post: 03-22-2011, 08:24 PM
  2. Incredible Running Slow
    By moliva1568 in forum Verizon Droid Incredible
    Last Post: 03-08-2011, 08:41 PM
  3. running slow
    By rhcmhc#AC in forum Motorola Droid X
    Last Post: 12-03-2010, 07:14 PM
  4. Replies: 13
    Last Post: 07-28-2010, 03:22 PM
  5. 2.1 running slow?!
    By sephiroth_darko in forum HTC Hero
    Last Post: 05-24-2010, 12:01 AM
