1. Dustin6707's Avatar
    I am in need of a case and belt clip that will fit a 2 1/4" belt (duty rig). Does anyone know of a good case/clip combo like otter box with that clip size? Even just a holster that would fit the phone with a otter box on it would work.
    Any advice would be great!
    Sent from my EVO using Tapatalk 2
    05-24-2013 12:18 AM
  2. vr002sh's Avatar
    Dustin,
    Not sure if it will fit a 2 1/4" belt, but looks pretty close. Both the Seidio Active and Surface cases with clip. I think you can only get the Active case online (here, Amazon or Seidio directly). However best buy sells the Surface case/clip combo under their own name (platinum). I think if you want more protection like a otter box, the Active would be the better choice. But since they use the same clip, going to Best Buy will let you know if the clip will work.
    The Active is NOT an OtterBox, it's good, but if you need the protection of an OtterBox, then you may not be happy with this.
    Just my 2 cents worth
    05-24-2013 08:44 AM
  3. rankar7's Avatar
    This has a 2.5" belt loop and thickness for your otterbox.
    Amazon.com: Samsung Galaxy Note & X-Large Slim Vertical Smart Phone Case / Pouch / Holster w Metal Clip, Velcro, & Belt Loop 5.8x3.4x0.50: Cell Phones & Accessories
    05-24-2013 09:01 AM
  1. Cases With Belt Clips?
    By cougmeister in forum HTC Vivid
    Last Post: 11-25-2011, 10:05 AM
  2. Body Glove Glove Snap-On Case with Belt Clip for LG Optimus S
    By SylvianDark in forum LG Optimus S Accessories
    Last Post: 08-27-2011, 02:25 AM
  3. case and belt clip solutions
    By W_T_F_13 in forum Thunderbolt Accessories
    Last Post: 05-17-2011, 02:37 PM
  4. Want and extended battery and belt clip combo
    By bradyapba in forum Droid 2 Accessories
    Last Post: 05-02-2011, 01:37 PM
  5. Case without belt clip ????
    By Hipgrncln in forum Droid X Accessories
    Last Post: 08-16-2010, 02:54 PM
