1. tireboy66's Avatar
    I use my note2 in my tow truck for extra tunage.. When its plugged into the stereo system it's a constant battle to keep the volume at any level.. i use the 3.5mm head phone jack .. Is there any way to bypass the stupid volume limiter???
    06-02-2013 02:45 PM
  2. tirith's Avatar
    Get the ibolt dock from amazon... uses the microusb on the bottom. Comes with the cable that splits into usb and 3.5 mm jack at the end.
    ~swyped from a galaxy (note 2) far, far away
    06-02-2013 04:18 PM
  3. jdub1981's Avatar
    So you are using a 3.5mm cable to connect to a 3.5mm audio input on your car stereo? Is this the only time the error occurs or does it also happen when using headphones?
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    06-02-2013 05:15 PM
  4. tirith's Avatar
    Anytime you plug that 3.5mm jack into the phone, it automatically goes down to about half volume
    06-04-2013 06:36 AM
  1. Vibrate and Volume control messed up on 2.2
    By MasterRattler in forum Motorola Droid X
    Last Post: 09-22-2010, 11:00 AM
  2. Volume Control not working after update
    By xocarrie in forum General Help and How To
    Last Post: 08-15-2010, 03:52 PM
  3. Sprint TV VOLUME CONTROL?
    By limitproof in forum HTC EVO 4G
    Last Post: 06-11-2010, 10:32 AM
  4. volume control on the side.
    By XCalibration17 in forum Motorola Droid
    Last Post: 12-17-2009, 08:03 PM
  5. lost volume control
    By AndroidFTW in forum HTC Hero
    Last Post: 11-05-2009, 09:28 PM
