1. inooon7's Avatar
    Hello there,
    Hope all are fine.
    Yesterday I bought my new SD Memory Card, and I put it in my Galaxy Note 2.
    Today I thought of encrypting it, but when I go to settings and enter to encrypting my SD Card, I get this:
    Any help please?
    As soon as possible.
    I'll really appreciate that.
    Thanks.
    06-14-2013 06:32 PM
  2. Trees's Avatar
    Are you wondering which options to select?
    06-14-2013 06:35 PM
  3. inooon7's Avatar
    No, I actually can't select any, you know "grey in color".
    06-14-2013 06:57 PM
  4. Connert's Avatar
    You need to back out one level and set a password. See "note" on the bottom of your screen shot.
    06-14-2013 07:30 PM
  5. inooon7's Avatar
    Ok but I didnt find that
    06-14-2013 08:18 PM
  6. Connert's Avatar
    Back one screen from your screen shot you will see "Encrypt Device". Give that a try. It should have you set up the necessary password.
    Golfdriver97 likes this.
    06-14-2013 08:26 PM
  7. Trees's Avatar
    Strange. I am able to duplicate your findings. Wonder if this feature is disabled?
    06-14-2013 08:28 PM
  8. Trees's Avatar
    Is that for the device internal SD card? Or is it a prerequisite to input password for the External SD Card? Not doubting you, but rather think its a poor implementation on Samsung's part.
    06-14-2013 08:31 PM
  9. Trees's Avatar
    Just remembered about this in the VZW seb forum. http://forums.androidcentral.com/ver...mory-card.html
    06-14-2013 08:43 PM
  10. Derick Ramos's Avatar
    tried that but with no luck still gray on the buttom part where it says encrypt device more detail pls .ty
    07-18-2013 01:53 AM
  11. Jean Gibran's Avatar
    Go back to "SETTINGS" and then "SECURITY" and in "SCREEN LOCK" it needs to be secured with a password and not with a PATTERN or SWIPE or PIN only PASSWORD
    then the encryption will be enabled and you would be able to encrypt your device and/or your SD card
    Password should be 6 caracters including at least one number
    Cheers
    07-22-2013 02:39 AM
  12. Lariza Carlson's Avatar
    Hi!
    Was this issue ever resolved? I have a Galaxy 2 (OLD School!) that I'm having the exact same issue with. I have a password security set, but the Encrypt Device and SD card options are still greyed out. I'm working with Samsung on this. They're having me try to download a Kies for the Jellybean OS (I currently have 4.0.4). If that doesnt work, they want me to go back to the default settings. We'll see... Wanted to see if you figured it out. Frustrating. I cant get work email/calendar until this is resolved!
    Thanks!
    09-10-2013 09:01 AM
  1. SD Memory Card not reading
    By Warrenisit in forum HTC EVO 4G LTE
    Last Post: 09-28-2013, 04:31 AM
  2. SD Memory Card class
    By parout66 in forum HTC EVO 4G LTE
    Last Post: 05-15-2012, 08:10 PM
  3. Issue with samsung galaxy sii in external memory card
    By jbcjeyes in forum Samsung Galaxy S II
    Last Post: 01-16-2012, 02:49 PM
  4. Replies: 3
    Last Post: 01-11-2012, 08:44 PM
  5. Replies: 0
    Last Post: 12-28-2011, 11:10 AM
