1. Randy Romesh's Avatar
    My note 2 takes a whole 7 hours to charge and discharges in less than 3 hours
    Please any one help me to solve this problem...
    07-11-2013 11:36 AM
  2. anon(6174973)'s Avatar
    Sounds like a battery issue to me.
    Sent from my GT-I9505 using Tapatalk 4 Beta
    07-11-2013 11:39 AM
  3. Randy Romesh's Avatar
    Actually I'm not using the stock charger.... I'm using another charger with 0.5 a ...... Could this be causing the problem..?
    07-11-2013 09:53 PM
  4. HypoDest's Avatar
    Almost definitely. The note 2 stock charger is a 2A one, which is usually reserved for tablets. Use a stock charger.
    Sent from my GT-N7100
    07-11-2013 10:21 PM
  5. anon(6174973)'s Avatar
    It could be the problem. Use the original one because that low current is charging your phone real slow.
    07-11-2013 11:57 PM
  6. Chris Flowers's Avatar
    It's more then the charger though. It'll take longer to charge because of the low current output however that shouldn't make any difference to the discharge time.
    Sent from my GT-N7105 using Tapatalk 4 Beta
    07-13-2013 01:37 AM
  7. Randy Romesh's Avatar
    Thank q all........... the problem solved its now charging much quicker than before..
    07-18-2013 11:03 AM
  1. Replies: 9
    Last Post: 01-08-2014, 01:19 PM
  2. 32GB Verizon Galaxy Nexus w/ Anker extended & Zero Lemon battery
    By Wobblin30 in forum Marketplace Archive
    Last Post: 09-06-2013, 08:23 AM
  3. Unable to charge device
    By Darkon84 in forum HTC One M7
    Last Post: 08-06-2013, 02:14 PM
  4. Htc one charging.
    By DeadlySkullz in forum HTC One M7
    Last Post: 07-12-2013, 02:23 PM
  5. Nexus 4 Charging time...
    By Mike_47 in forum Google Nexus 4
    Last Post: 07-11-2013, 10:44 AM
