My Issue:
the problem i have is that after doing a lot of reading and browsing this and other forums i installed a few different kernels and then started with roms, and now discovered neither Bluetooth or usb works Ive tried many different things including restoring back to stock rom and kernel rebooting several times both PC and phone, ive tried a few other things that seemed to fix for others i installed the drivers at least 9 times now and kies over and over, also tried the galaxy note tool kit but it just wont see the phone it just charges it ive also tried a different cable and the same problem is there... the only option ive not tried is to completely remove root and start again, but the problem i have is that if that doesn't fix it is that i wont be able to root again through odin,
Ive enabled usb debugging etc also nothing im really lost with this now as want to transfer files
Notes:
1- download new room and wipe data and cahe and also the proplem
2- change the cable
3- read on odin normaly but kies dont read
Thanks in advance
07-12-2013 03:32 PM
