Verizon Note 2: Outgoing calls failing (+) plus sign added to incoming numbers in call log
co24
All incoming calls in Verizon note 2 come with plus sign on front of area code. If I try to call it won't go through, It recently started doing this. I even did a factory reset and nothing, please help.
Sent from my iPad using Tapatalk HD
MercuryStar
47
Re: Outgoing calls failing (+) plus sign added to incoming numbers in call log
Sounds like a carrier issue. On a mobile phone "+" is the equivalent of your international dialling prefix. If you start a number with "+" you need to follow it with the international country code, then the rest of the number as if dialling internationally (it's safe to do this even with local numbers; you won't be charged an international call cost).
If incoming calls have a "+" at the start but don't have a valid international dialling code (eg "1" for the United States) preceding the rest of the number, then it sounds like a bug with the carrier.
rsadalarasu
10
Did you ever got this problem resolved? I m in the same boat :(:'(
nlitenme
545
This is just a guess, but...
Go into your Dialer, tap the Menu button, go into Call settings, then under Other call settings, do you have U.S.A. listed under both Current country & in the Assisted dialing settings?
Sent from T4 in my N2
ameenhack
Did you ever got this problem resolve this thread im in the same boat :(:
Duard
109
6
Hi, ameenhack. Please clarify, are you seeing the plus without the 1 in the incoming call log for numbers that are found in your contacts, for numbers that are not found in your contacts, or both?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Try disabling assisted dialing
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
domush
4
I'm in the same boat, using at&t with straight talk. All incoming calls have a + in front of the area code (without a 1). This only happens to incoming calls. The call log shows outgoing calls just fine, no + in front.
I've tried assisted dialing settings, changing countries, changing roms. I'm at my wit's end. I need to be able to call people back!
yolanda Mak
Same problem here. i called Samsung they said its network issue & I should contact AT&T. Per AT&T, technical support for phone not purchased from them is limited. Does anyone have solution to this problem? pls help.
galaxys5question
Hi there,
Have you fixed the problem? I have the same issue and the carrier can not figure out what to do. I have done factory reset, and still the problem is there.
prepaidguy9081
424
Phone
Phone settings
Advanced phone settings
Auto areacode
Is this on or off, mine is off, no issues
Tmobile note ii, unlocked, cricket wirless (att mvno), jedix20 rom, android 4.1.2
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
Kenny McDonald
I found this issue to be a pain in the you know what and struggled to fix this issue for a few months. I finally fixed it today and thought I would share my fix.
Go to Settings > Call> other call settings> Assisted dialing.
Select the settings and delete all the details. Then toggle to off. Works on my Verizon Note 2 running AT&T Sim card through Straight Talk;)
myrealtygal
11
"Go into your Dialer, tap the Menu button, go into Call settings, then under Other call settings, do you have U.S.A. listed under both Current country & in the Assisted dialing settings?"
Thank you, thank you! All better now.....
sangleweb
It does not work for me either :(
This one is driving me crazy. Prefixer does not work either. Always the + before each incoming number.
Samsung Note 3 900V...ex-Verizon phone on Cricket (ATT) network.
I am having the same issue with not just Note 2 but all the VZ Samsung using Straight Talk AT&T sims card. But when I put on VZ LG, iPHone or Droid Turbo phones, the incoming calls coming as as expected. Prefixer works ok but still not for replying text and incoming still has a plus. My test case includes VZ Note 3 - having plus but AT&T Note 3 does not which tells me Samsung somehow detects it's a foreign SIMs and automatically add the plus sign.
cganesh
Active member
Jan 6, 2015
27
Using VZ note 2 with ATT sim. Prefixer works to remove the + sign as long as you allow the Prefixer program to pop-up to show "call being handled by prefixer" before answering the call. I also had to add a third party answering service program since the existing one was tied to VZ service. Using InstaVoice which works great. On calls that get answered by InstaVoice the + sign still comes up on the missed call number. I have just gotten accustomed to doing a quick save of the missed call number if person left a message and not in my contact list. Once in contact list, remive the + and re-save. I don't seem to have any issues with + once the caller is in my contact list. Good luck. I was also not able to get my hotspot to work due to issue in a program that loads at bootup. Installed FoxFi and paid their fee once I tested it and found it worked. I am on a data plan with ATT that allows tethering and hotspot use so I'm legal with ATT. Thinking about changing to Straight Talk but getting the SIM that is Verizon network. Hoping some stuff might work better back on a Verizon network.
NalaSweet
Download an app called prefixer then open app and manually add rule to reject enter \+ it works!!!!!! Make sure to add rule to incoming and out going
educationalco22
