1. umer yes's Avatar
    i got my note 2 yesterday and i used it the whole day with wifi constantly on(browsing), listening to music, with sync off everything is perfect the only that bugs me is the fact that it only lasted 5 to 6 hours.Does your note 2 last the same when using it heavy or is there something wrong with my battery or phone? and one thing more, when i view my battery drain apps, google chrome is usually the 2nd or 3rd on the list, is this normal? honestly i was expecting much more from this phone battery wise....thanks
    07-31-2013 04:13 PM
  2. iOS Gravity's Avatar
    Normal with wifi on. It drains the battery a lot. Make sure that gps is off. Chrome is probably on the top of the list due to you using it to surf the web a lot. By the way, I think it was unessesary to have started 2 threads on one topic.
    07-31-2013 04:24 PM
  3. nlitenme's Avatar
    Welcome & congrats on getting your N2!
    Batteries normally don't come fully charged from the factory. Also, they usually take a week or so to build up to their max usage time. Give it some more time.
    And like galaxyboy said, you don't need to create multiple (I see 3 so far) threads for the same subject. The mods are very good about making sure they're in the right place.
    07-31-2013 04:38 PM
  1. Verizon Galaxy S3 : Battery status icon won't go away!
    By Nussbuss in forum Verizon Galaxy S III
    Last Post: 05-30-2014, 08:07 AM
  2. good and secure note app.
    By steveinil in forum Android Apps
    Last Post: 03-04-2014, 01:31 AM
  3. Help Me Convince UAG to Create A Galaxy Note 8 Case
    By harryhoudini66 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 08-06-2013, 04:28 PM
  4. Galaxy note 2 battery questions...
    By umer yes in forum General Help and How To
    Last Post: 08-01-2013, 10:30 AM
  5. Looking for a Note owner for a favour
    By jwn66 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 07-31-2013, 07:13 PM
