I feel like it should be better
If you would please, post screenshots of your battery stats in settings. Both the usage, and the graph. Those are much more helpful in deciphering battery life.
Signal strength is the biggest factor.
Sent from my SPH-L900 using Tapatalk 4
How so?
How so?
I finally had a chance to look at your pics. Your device is waking up a lot. Not that good. I would get an app called Wakelock detector and see what is going on. I would guess FB. If true, then go into settings and change the refresh rate. By the amount of wake times, I would guess every 15 minutes? If so, then every 15 minutes, your phone is waking up to check status updates.
I am also guessing the GPS is on? Turn that off, and you may see improved battery life.
I downloaded that app and saw how often certain apps were going off, deleted some and changed some settings so hopefully thatll help out more, thanks for all yoru help!
