Save big + get 3 months free! Sign up for ExpressVPN today
  1. cdf3's Avatar
    I plug my Galaxy Note 2 up overnight to charge. There are times when I wake up the next morning and my battery is only around 30-40%. I look at the battery stats and see that it was charging for a brief period, then stopped. Some nights it will charge to 100%, and there are times when it stops charging in the middle of the night.
    Does this happen to anyone else? I'm not sure what's causing this.
    Sent from my SCH-I605 using Tapatalk 2
    09-13-2013 04:03 AM
  2. mufaddal.ezzi's Avatar
    I never had this problem.. but what i suggest is either to change the charging unit or the charging port is loose..
    Sent from my GT-N7100 using Tapatalk 4
    09-13-2013 04:11 AM
  3. Hasbrobot's Avatar
    Same thing happened to mine and my wife's. It was strange they both started doing it around the same time?
    It wasn't until further examination that I realized both chargers were faulty. I replaced them but it still doesn't seem to charge quite like normal but it was at least charging to 100 percent again. As of right now we both gave up on the Samsung chargers and each use our nexus 7 chargers and they charge in normal time again. Just my 2 cents good luck!
    Sent from my SGH-T889 using Tapatalk 4
    09-13-2013 07:36 AM
  4. cdf3's Avatar
    I may give that a try.
    If I use the same charger to charge my 2nd battery using the Samsung external charger, it'll charge the battery to 100% with no problem. Most times it charges my Note II just fine, but every now and then it does not. I also noticed a lot of activity under the Awake section of my battery stats. Not sure if it's an app that's causing the issue.
    09-13-2013 10:41 AM
  5. bunnybash's Avatar
    I changed the usb cable and that fixed the issue for me.
    09-13-2013 12:37 PM
  6. Jude526's Avatar
    Sounds like a bad charger. I had that same problem with my Rezound and it was the charger
    sent from my amazing Note2
    09-14-2013 04:42 PM
  7. cdf3's Avatar
    When I have the issue something is constantly cycling awake mode. My phone has been charging for 6 hours, and the battery has only gone from 30% to 50%. Can't find out what's running in the background. Tried finding it in GSam battery monitor app, but it's not showing up.
    Attached Thumbnails What makes my Note 2 stops charging?-uploadfromtaptalk1379577787269.jpg
    09-19-2013 03:03 AM
  1. Does Note 3 Have LED Notifications?
    By recDNA in forum Samsung Galaxy Note 3
    Last Post: 01-20-2014, 05:13 AM
  2. My S4 and LG G2 Comparison (Ongoing)
    By WickedRabbit in forum Samsung Galaxy S4
    Last Post: 01-03-2014, 10:52 PM
  3. Just had my first random reboot
    By josh6113 in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-15-2013, 04:29 AM
  4. Help! Tried rooting, Now Stuck. Dont know what to do!!
    By porkchopf150 in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 09-30-2013, 03:37 PM
  5. Fastest charging USB
    By Man In Black 805 in forum Samsung Galaxy S4
    Last Post: 09-13-2013, 08:58 AM
