1. mrscaston30's Avatar
    I turned my phone off the other day and removed the battery for all of three minutes and when I turned it back on, most of my preset preferences were gone. Now I am afraid to turn it off ever again. Is there a way to lock in my preferences so that I don't have to reset them every time I turn my phone off and on? Is this an issue or just the way the notes work?
    09-18-2013 08:39 AM
  2. jdub1981's Avatar
    You need to specify which preferences and why exactly you needed to do a battery pull.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
    09-18-2013 08:41 AM
  3. metle_geek's Avatar
    Ok if your rooted and you dont have a perm root su.zip or supersu.zip this will happen every time and if your on an odexed rom
    Sent from my HTC One X+ using AC Forums mobile app
    09-18-2013 08:52 AM
  4. mrscaston30's Avatar
    My third party keyboard disappeared and my background picture disappeared, and my multi screen bubble disappeared. Those are the three I noticed-can't remember anything else at the moment. I pulled battery to see how many gigs my phone has. Didn't think to look in settings.
    09-18-2013 09:01 AM
  5. mrscaston30's Avatar
    Def not rooted. That's foreign to me. I have all the original functionality on phone.
    09-18-2013 09:02 AM
  6. jdub1981's Avatar
    If you bought your phone from a US carrier then you have a 16gig phone.
    Keyboard problems happen to me as well. My phone constantly forgets keyboard preferences. I have since stopped using that keyboard so I cant help in those regards. Multiscreen bubble? I assume you mean the bubble that allows you brings apps on screen. If it has disappeared then you need to either make sure its activated in your notification panel and if it is then while on the home screen push and hold the back button for a few seconds, this activates the bubble.
    09-18-2013 11:31 AM
  7. lostchild's Avatar
    Not sure about others, but keyboard will go back to Samsung every single time after reboot. It is a known issue on early versions of Jelly Bean. I think it was supposed to be fixed in 4.3, but I don't have 4.3 yet.
    mrscaston30 likes this.
    09-18-2013 11:35 AM
  8. mrscaston30's Avatar
    Ok thanks. Its not super major, just a little irritating to have to do it again and again. Sometimes I take screenshot of my apps and what page they are on because I'm afraid they will disappear and I won't remember which ones I've had. That happened on my HTC One pretty often.
    09-18-2013 11:56 AM
  9. jdub1981's Avatar
    The screen bubble is supposed to do that. It how to turn it on and off. Persobally I havent used multicscreen in many months so I leave it off. Hopefully I helped in some way.
    09-18-2013 12:14 PM
  1. Replies: 4
    Last Post: 01-29-2017, 03:54 AM
  2. Replies: 3
    Last Post: 11-03-2016, 12:07 AM
  3. Accidental power off
    By Larry Robbins in forum Samsung Galaxy S4 Active
    Last Post: 09-19-2013, 11:13 PM
  4. Reseting Problem, phone will crash
    By streamca in forum Google / Samsung Galaxy Nexus
    Last Post: 09-18-2013, 07:23 AM
  5. Down loading multiple photos
    By GNX231 in forum Google+
    Last Post: 09-18-2013, 07:18 AM
