1. Mike Lang1's Avatar
    hi all,
    how do I remap/reprogram the HOME function to the MENU key? Since the soft keys are a lot easier to press,
    I like to do something like:
    - press once on MENU to do 'menu' (as before)
    - double tap on MENU to do 'home key'
    Mine is running stock 4.1.2 and rooted.
    Thank you.
    mike
    10-21-2013 01:39 PM
  2. B. Diddy's Avatar
    Try Nova Launcher. You can do exactly what you're describing, except that it would be a long-press of the Menu button instead of a double press.
    10-21-2013 05:27 PM
  3. Mike Lang1's Avatar
    Found the solution: I purchased "Xposed Additions" that lets me to remap any key (softkey and hardkey).
    Worked perfectly.
    It needs Xposed Framework but I used it to run Xprivacy already.
    - - - Updated - - -
    Thanks. But it only works when you are on the home screen. Not inside an app.
    11-18-2013 09:59 AM
  4. B. Diddy's Avatar
    Ah, good point.
    11-18-2013 03:19 PM
  1. Galaxy Note 10.1 - S-Note Page Layout
    By zr2s10 in forum Samsung Galaxy Note 10.1
    Last Post: 04-15-2014, 02:23 PM
  2. Galaxy S3 - Restricted number going straight to VM despite
    By jokeyhaha in forum Samsung Galaxy S3
    Last Post: 10-28-2013, 01:46 PM
  3. Samsung Galaxy Nexus overheats. What to do?
    By gnr_2 in forum Sprint Galaxy Nexus
    Last Post: 10-24-2013, 01:46 PM
  4. samsung docking keyboard for Galaxy Note 10.1 (Please Help)
    By Joe Bradley in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 10-22-2013, 09:31 AM
  5. HTC One, idle animations ON/OFF
    By Jonathan Dale in forum HTC One M7
    Last Post: 10-21-2013, 04:48 PM
