Re: Battery Drain after 4.3 update
Could you post some numbers on how bad the battery drain is. For now I have no idea how bad is your bad.
Yes sure..I was about to post the screenshots from wakelock detector, stock battery app, etc. Will post those soon for you to have a look.
It's like something is wrong,
1.Merely unlocking the phone and mumbling around here and there like browsing the music or changing songs eats 1-2% battery.
2.At night if I leave the phone at 100 %, by morning it used to be at most 90%, but now, it drains to almost 70%.
3.Idle phone (sync OFF, Mobile data/Wifi ON, Quick glance ON) consumes around 7% per hour.
4.Even the power saver mode does not seem to be working anymore (same amount of battery drain)
All of the above started happening after the 4.3 upgrade. I was very happy with the battery life with 4.1.2.
P.S Now I have turned off WIFI/Data and observing the phone with
1.Auto brightness
2.Quick Glance enabled
3.Smart Stay ON
4.Power Saver OFF
