1. juicesrwild's Avatar
    Hello,
    I'm from Toronto and had the 4.3 upgrade on my phone last week, probably Dec4-6. Since then my apps keep arbitrary opening, my music, my games, dialing pad.. its like my phone is on drugs! I'm frantically trying to close the apps only for others to open up simultaneously.
    Also some of my apps stopped working and had to re-install them in order for them to work.
    Anyone having issues? Anyone have any fixes or heard of any possible fixes available or in the future?
    12-10-2013 11:28 AM
  2. Gurdeep Saluja's Avatar
    The new upgrade pushed 4.3 is a nighmare it will drian battery in less than 2 hours not sure how to get rid of it
    12-10-2013 11:45 AM
  3. juicesrwild's Avatar
    I read on another post to get rid of the "Knox" App.
    12-10-2013 01:26 PM
  4. eekfu's Avatar
    I have a note 2 with 4.3 update. My battery is fine, and the apps is normal.
    12-11-2013 01:42 AM
  5. zaydabarber's Avatar
    Do a master reset that will take care of it
    "AT&T Samsung Galaxy Note 2"
    12-11-2013 01:50 AM
  6. Eric troy's Avatar
    I'm having trouble with my note 2. Ever since the update my phone freezes and i keep restarting it. Did the master reset , battery pull et all. Nothing is working. Any suggestions?
    12-11-2013 08:06 AM
  7. 1812dave's Avatar
    You don't know that.
    12-11-2013 12:06 PM
  1. New screen issues
    By bgrushin in forum Verizon LG G2
    Last Post: 06-30-2014, 03:05 PM
  2. Battery issue
    By tweakage in forum Google Nexus 5
    Last Post: 12-14-2013, 06:40 PM
  3. Wallpaper help
    By ::Montgomery:: in forum Wallpapers, Ringtones, and Themes
    Last Post: 12-11-2013, 09:09 AM
  4. Lenovo S2110 Charging Issue
    By rainehinata in forum Lenovo Android Tablet Discussion
    Last Post: 12-10-2013, 11:49 AM
  5. HELP - deleted music in misc files
    By Katie Akrigg in forum Android Apps
    Last Post: 12-10-2013, 09:37 AM
