1. xiaohao76's Avatar
    My note 2 was drenched in rain a few weeks back, it was treated with hair dryer (I know its a dumb idea), then the parts were dismantled and put into a container of rice to absorb the moisture.
    Touchscreen and everything still works as long as you know wherever you touch takes you to lol. I'm suspecting it might be a problem with the motherboard. Can anyone confirm or advise me on a solution?
    Your help is greatly appreciated!
    11-19-2014 04:04 AM
  2. AndroidProf's Avatar
    A hair dryer aint a dumb idea, just make sure it doesn't fry the screen. I am not sure what you are seeing, is the screen colored or is it back to normal? If the phone functions but you cannot see clearly, then you can either replace the screen or you can use it as it s(if its usable) and later the screen will clear, but you will have to keep an eye on the moisture.
    11-19-2014 03:30 PM
  1. Why can't I get my USB keyboard to type on my Samsung Tab 3 7.0?
    By iwantmylaptop in forum Samsung Galaxy Tab 3
    Last Post: 12-03-2014, 12:30 AM
  2. What has the No command. screen appeared after turning off my phone?
    By failgo in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-19-2014, 11:53 PM
  3. May not be only for the Note 4 but...
    By iGalione in forum Samsung Galaxy Note 4
    Last Post: 11-19-2014, 06:40 PM
  4. Portion of LG G2 Screen Unresponsive. Help?
    By Nick Wason in forum LG G2
    Last Post: 11-19-2014, 03:35 PM
  5. Portion of LG G2 Screen Unresponsive. Help?
    By Nick Wason in forum Ask a Question
    Last Post: 11-19-2014, 06:25 AM
