1. Charles Crosno's Avatar
    wife broke my lcd screen on my note 2. ordered the part for it and swapped everything out last night. put it all back together and turned it on and it flashes a streak of colors on the screen for a second and turns off. the phone boots just fine and my computer reads it. is there anything im missing or should I go back to the company I got the lcd screen from?
    11-23-2014 09:04 PM
  2. Rukbat's Avatar
    This is why my advice to anyone asking about replacing a screen is "don't". You may have put the plug in wrong. Or filed to lock it. Or pinched a wire. Or broken something. You should have plugged the screen in with the phone open, then tried it. Now you have 2 choices, you can open the phone again, see what you did wrong and fix it (which may require replacing more parts) or you can find a shop willing to work on a phone you've already worked on (which most won't - I never allowed that in any cellphone store I owned, it's too expensive when we tell the customer that the repair is going to be more than the phone is worth, he leaves without paying and we're out 5 hours of labor and we have a phone worth scrap in parts.)
    It's why I always say that it's cheaper to pay to have it fixed the first time, than to have it fixed after you've broken more than was wrong with it at first.
    11-23-2014 09:19 PM
  3. Charles Crosno's Avatar
    the kit that I ordered was pretty simple. take the connectors off the board and the case and glue off. I did notice that the home button flex cable was damaged.
    11-23-2014 09:53 PM
  1. Lollipop - Black Screen
    By DirtyHarree in forum Legacy Android & Other OS's
    Last Post: 04-21-2016, 07:40 PM
  2. Why won't my Note 2 charge once the battery is dead?
    By kr632 in forum Hardware Hideaway
    Last Post: 07-25-2015, 10:44 PM
  3. Note 4 or Nexus 6...
    By mrdapper5 in forum Samsung Galaxy Note 4
    Last Post: 11-23-2014, 09:47 PM
  4. help shattered screen on lg g2
    By sbctony in forum LG G2
    Last Post: 11-23-2014, 08:05 PM
  5. Why does my screen say System Software not authorized?
    By kbarry2323 in forum Samsung Galaxy S5
    Last Post: 11-23-2014, 07:42 PM
