I will connect it to the Telstra network and it will have a pop up saying registered on network and if I run out of service it will drop off the network and so I have to register it again how can I fix this ?
Well, I would say why don't you try talking with the customer support people about the same as if the network keeps dropping means the problem is with your service provider.
