1. AC Question's Avatar
    could you please advice why the usb connection failed between my PC with Win8 operating system and Note 2 10.1
    and how I can get the drivers
    04-19-2015 06:03 PM
  2. Rukbat's Avatar
    From SAMSUNG_USB_Driver_for_Mobile_Phones. Unplug the tab from the computer, install the driver, let it finish installing, then plug the tab in.
    04-20-2015 12:26 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! If that doesn't work, try here: Support - Wi-Fi Tabs SM-P600 | Samsung Galaxy Tab. I'm assuming you have the Note 10.1 2014 Edition.
    04-20-2015 12:51 AM
  1. need solution for note
    By MaLik Hadi in forum Ask a Question
    Last Post: 04-19-2015, 11:21 PM
  2. S6 or Note 4?
    By thezeke in forum Samsung Galaxy S6
    Last Post: 04-19-2015, 08:59 PM
  3. hi I just got the galaxy S6 edge and tried to install the gear manager
    By joseph banda in forum Samsung Galaxy S6 edge
    Last Post: 04-19-2015, 08:25 PM
  4. How do I disable the smart remote on my Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 04-19-2015, 06:51 PM
  5. Nexus 6 does not auto detect external USB devices
    By az86018 in forum Ask a Question
    Last Post: 04-19-2015, 06:12 PM
