1. duhhitsdaniel's Avatar
    I have to Note 2s im going to do glass replacements on and im wondering whats the best way to clean the old glue off the lcds. I used 91% iso and a paper towel on an iphone and i just ended up scratching the hell put of the screen. Also, the new glass came with adhesive, so should I still use loca glue? And would anyone reccomend a mold? Id really appreciate any advice thanks.
    06-26-2015 04:41 PM
  2. duhhitsdaniel's Avatar
    Yes I can. Its double sided tape
    06-26-2015 04:54 PM
  3. firbeestix's Avatar
    Myself and other people have had bad luck using a heatgun to remove the adhesive from lcd. So dont so that! I usually buy the lcd and glass as a single part and do that swap. Imho doing the glass alone is really hard without the correct machine to heat and remove and reapply the glass.
    07-07-2015 09:23 AM
  1. Purported Galaxy Note 5 case renders appears
    By Yathani in forum Samsung Galaxy Note 5
    Last Post: 07-10-2015, 01:35 PM
  2. Samsung Galaxy Note 3, Lollipop Update?
    By Francis Macdonald in forum Samsung Galaxy Note 3
    Last Post: 07-01-2015, 04:59 AM
  3. Replies: 3
    Last Post: 06-30-2015, 06:25 PM
  4. Tempered Glass Screen Protector Bubble
    By seanthedennis in forum Ask a Question
    Last Post: 06-29-2015, 12:37 PM
  5. Replies: 1
    Last Post: 06-27-2015, 12:08 AM
