1. J79F104's Avatar
    I have a factory stock Samsung Galaxy Note 2 with Verizon purchased new in July 2011 and it is consuming battery power about 5 times faster than it use to. For example, turned on with no use, it is burning the battery at about 10% per hour. With use like reading newpapers on websites or shooting and watching video, I would estimate 25-50% per hour battery consumption. Wifi, GPS are off. This seemed to occur about early to mid 2015. I called Verizon and they said they have had no reports of such. Can anyone help me with this problem please?
    09-15-2015 11:55 PM
  2. Hielko's Avatar
    The Note 2 didn't exist yet in 2011. But if you mean that the device is several years in use, buy a new battery.
    How to check on battery consuming apps is already described at many places.
    09-19-2015 01:13 AM
  3. B. Diddy's Avatar
    Duplicate, see response here: http://forums.androidcentral.com/sam...ml#post4693761. Thread closed to prevent parallel discussions.
    09-19-2015 01:13 AM
  1. ringer silent after using Square Reader
    By CapnDaveNC in forum Motorola Droid Turbo
    Last Post: 09-17-2015, 10:17 PM
  2. Replies: 1
    Last Post: 09-16-2015, 11:14 AM
  3. Lost the data by using scribble, how can I get my information back?
    Last Post: 09-15-2015, 11:09 PM
  4. Will Galaxy Tab 3 have connectivity issues in Italy?
    Last Post: 09-15-2015, 10:44 PM
