1. AC Question's Avatar
    As I said in the title, this been happening alot in the last few days and I can't find out why. I checked the pins of the the phone and they seem to be connected to the battery well and they look to be fine (not broken or something) and tried to clean the battery pins although it doesn't look dirty. But the phone keeps shutting down sometimes and as I said it mostly happens when I put it down in my pocket.. So what's the issue here? could be something related to when the phone is flipped or something?
    07-11-2016 06:00 AM
  2. H3aTeRzz's Avatar
    Its unfortunate that there are a few things that could be wrong. Your first troubleshooting should be to replace the battery, if you can. This will eliminate the battery as being the issue. (check the battery to make sure its not misshaped or swolen.)
    Next would be to try clearing the partition cache in recovery, then lastly, a factory reset.
    Hope this helps!
    07-11-2016 06:53 AM
  3. mojo1444's Avatar
    Hi have you try turning off the pocket detection mode... if this makes no difference there are couple of free apps design to check the phones sensors to make sure you're phone is working properly!!
    07-19-2016 06:51 PM
  1. My note 4 ir led is not working
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 10-19-2016, 03:04 PM
  2. My ir led stopped working
    By Qazi Inam in forum Samsung Galaxy Note 4
    Last Post: 08-03-2016, 08:34 AM
  3. Keeps asking me to sign into google, but wont sign in
    Last Post: 07-11-2016, 06:58 AM
  4. Replies: 0
    Last Post: 07-11-2016, 05:45 AM
