Does anyone know is the battery for the samsung note 2 the same as the note 3 ??
Dose anyone know does the battery from a samsung note 3 fit a samsung note 2 my Daughters battery died and I need to get her a new one ?
Re: Does anyone know is the battery for the samsung note 2 the same as the note 3 ??
Originally Posted by
AC Question Dose anyone know does the battery from a samsung note 3 fit a samsung note 2 my Daughters battery died and I need to get her a new one ?
I have no idea if a Note 3 battery will work in a Note 2 but if you need to get her a new one why not just buy one that's made for a Note 2? The Note 3 uses a 3200mAh battery while the Note 2 uses a 3100mAh battery but that's a negligible bump up in capacity so even if dimensional-wise the two are the same I'd just stick with a Note 2 battery replacement. If it were a matter where she had a spare Note 2 to supplement her daily usage phone than it might be worth experimenting. Just my opinion of course.
https://www.amazon.com/Samsung-Lithi...cUvbUpU5727742
