donm527
I was getting flares with mine on so I took it off, but I'm nervous about the glass so I may order another one.
Clears right? Gonna go with blacked out around the lens?
Even without a camera protector the flash will cause a color shift. I avoid using the flash for the most part.Did anyone tried to use flash with installed camera protector? Mine produces blueish images with flash.
Yeah I may try those.Clears right? Gonna go with blacked out around the lens?
They cutout for the flash and laser but not the lenses??
Nice install. You got yours nice and straight unlike yours truly. I have enty of spares though.
I am giving these a try but not sure I'll keep it. It depends on whether it interferes with the camera. I got one with holes for the flash and laser focus to avoid any flare and problems but I'm weary about dust getting in there. So far it doesn't seem to degrade picture quality..
Here is the link but the price has jumped up ridiculously. I got it for $7.85 but now it's $11.99?!You have a link to these? Or the name of the company. I need to replace my WSD ones now. They're not good for flash pictures.
https://www.amazon.com/dp/B08BNPWKCP?tag=hawk-future-20&ascsubtag=UUacUvbUpU6842050
Even with the cutout on the flash and laser, you still had a blue haze? Like as if you were taking a picture in a smokey room?
This is what I got with the WSD camera protector. Compared to my N10+, that has no lense cover...
That’s why I asked above... they made cutouts for the flash and laser but not the lenses??
If you see the reason why they made cutouts for those two to not cause performance issues with light waves being refracted through the protector going out, it’s not hard to understand why the performance with the protector covering the lenses. Adding an extra layer of glass for light to have to get through, it could be youre going to get light rays refracting causing issues.
Isn’t Samsung’s own protector for the S20U have the cutouts for the lenses? As well as the rest of the cover being blacked out?
Agreed, there should nothing over that camera lens that's not specifically designed to be there with the exception of add on lenses.
I ordered this
If there are cutouts I don't think there should be an issue.Now that you say that, I think I'll just put the camera lens protectors I ordered straight in the drawer..... I'll try one first maybe but it does make sense to leave it alone
At least the lenses areas are cut out.
Also the front facing camera. I mean my note 8 had cutouts for the front sensors so I don’t know why I see front protectors covering the camera.
Thanks. I think I found another one for $1 less. Did you test camera samples with the flash, to see if you still get the flare/haze?
