1. iFortWorth's Avatar
    So, absent of a TV, any idea if wireless Dex, on the N20, will somehow work with either OSX or Windows, or my Chromebook for that matter. Thanks
    sincere11105 likes this.
    08-10-2020 10:40 PM
  2. SpookDroid's Avatar
    Nope, unless there's a way to emulate wireless display on your computer (if there is I do not know of it). The tablet looks for the Wireless Display protocol supported by most modern TVs (sort of what Miracast used to be) or compatible Samsung Displays.
    That being said, DeX does work with Windows computers via a wired connection, and there hasn't been an announcement made on that front on whether that particular application would also work over WiFi (like current mirroring does on phones).
    iFortWorth likes this.
    08-10-2020 11:14 PM
  3. ZuperioKing's Avatar
    Wireless Dex at the end of 2020 will work wireless with Windows and MacOS. At this time, it is only available on TV's. Please reference the unpacked event on Aug 5th.
    08-11-2020 06:41 AM
  4. iFortWorth's Avatar
    Thanks!
    08-11-2020 07:00 AM
  5. SpookDroid's Avatar
    Thanks! Didn't watch the event, so must have missed that bit on the reports.
    08-11-2020 01:25 PM
  6. james702283's Avatar
    It should work with firesticks mirrorcast at least for now
    SpookDroid likes this.
    08-11-2020 01:27 PM
  1. Samsung Dex & mobile working
    By kevjey in forum Samsung Galaxy Tab S6
    Last Post: 08-08-2020, 08:17 AM
  2. ATT wireless plan upgrade
    By eddie rivera2 in forum Ask a Question
    Last Post: 08-02-2020, 05:50 PM
  3. Screen Orientation In Tab S4 running DeX.
    By DennisOS2 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 07-16-2020, 08:11 AM
  4. Samsung J1 says "Verizon Wireless not authorized"?
    Last Post: 07-12-2020, 12:13 PM
