So much for the phone being water resistant.
I wonder how long it took for the lens to dry out. It happens to my sunglasses all the time, but they dry out very quickly- seconds. Even so, this isn't expected from a flagship device.
Sorry but this can happen from temperature extremes. Let's not all panic.
I can assure you this can happen when going through extreme temperature changes.View attachment 323915
It probably could , wouldn't doubt it , but never seen on any phone I had that was certified IP water and dust . I've seen in older phones without it ip certifiedI can assure you this can happen when going through extreme temperature changes.View attachment 323915
It gets humid in a lot of places. I said extreme temperature changes. There is air inside your phone is at atmospheric pressure. They do not pull or seal a phone in a vacuum, nor is the phone air tight. We don't know how the phone was handled.Never happened before that I recall. It doesn't get more humid than NOLA/ Houston. Why my stuff isn't fogging up now?
IP68 is not air tight and if you Google the issue you'll see that it happens. I'm not going to let one article ruin my day.It probably could , wouldn't doubt it , but never seen on any phone I had that was certified IP water and dust . I've seen in older phones without it ip certified
Be dangerous with a battery , No ?It gets humid in a lot of places. I said extreme temperature changes. There is air inside your phone is at atompheric pressure. They do not pull or seal a phone in a vacuum, nor is the phone air tight. We don't know how the phone was handled.
