10-03-2021 11:50 PM
85 123 ...
tools
    So, I'm confused. A few websites I've visited say that the Note 20 Ultra only does 25 watt fast charging, but then a few others say it does 45. And Marques said it does 45, but that doesn't match what I've read elsewhere. Anyone know for certain?
    08-18-2020 02:43 PM
  2. mustang7757's Avatar
    We won't know for sure until we get them in our hands, I've heard support both then I also hear just 25w.
    If you have futher questions ,I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    08-18-2020 04:12 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I moved this to the Note20 forum for more specific traffic.
    08-18-2020 04:12 PM
  4. ClintRo's Avatar
    I will do a test video when I get mine for you all.
    mustang7757 and mgbosshogg like this.
    08-18-2020 04:13 PM
  5. Mike Dee's Avatar
    Even if it did support fast charging it wouldn't make big difference except at the low end of the charge cycle. Charging it from zero the gain is about 6 to 8 minute difference with 45 watts on the S20 Ultra.
    08-18-2020 04:47 PM
  6. airkorea08's Avatar
    The Samsung website says 25w fast charging so thats what I'm going with.
    j_hansen likes this.
    08-18-2020 06:31 PM
  7. bhatech's Avatar
    Most reviews don't care about smaller details like this. They care about shiny shots of the phone and presentation. According to Samsung it only supports upto 25W fast charging so I'll go with that. Personally I don't care about about how fast it charges, never been a criteria for me.
    monsieurms likes this.
    08-18-2020 09:03 PM
  8. ihbsbA's Avatar
    One thing I love about my Note 10+ is how fast it charges.
    mustang7757 likes this.
    08-18-2020 09:30 PM
  9. mustang7757's Avatar
    I have no complaints with 25w charging its very fast
    08-18-2020 09:34 PM
  10. Serkle K's Avatar
    Same here. I put it on the wired charger in the morning as I am getting ready, and as soon as I'm done, I'm usually anywhere from 95-100%.
    mustang7757 and ihbsbA like this.
    08-18-2020 09:38 PM
  11. mustang7757's Avatar
    Later on like to try the 15w wireless charger , i have older version of Samsung 2018 .
    08-18-2020 09:40 PM
  12. Serkle K's Avatar
    Yeah, I am thinking about upgrading a few of my wireless chargers to that too. The last wireless charging pad I got was part of the Note8 accessory bundle from BestBuy. Its the brown one that flips upright or lays flat. I believe its only 9W.
    08-18-2020 11:20 PM
  13. mustang7757's Avatar
    I always upgrade my accessory years later for some reason they not priority.
    Serkle K likes this.
    08-18-2020 11:24 PM
  14. KupKrazy's Avatar
    Part of me says that 25w is totally fine - it's already so quick. The other part of me is hoping that 45w also works for the people that spent so much money on the 45w charger. lol
    08-18-2020 11:28 PM
  15. miamiborn79's Avatar
    If it doesn't work, I wonder if it will charge it at 25w by default? At least then it'll be like having an extra 25w charger.
    08-19-2020 12:53 AM
  16. KupKrazy's Avatar
    I'm pretty positive it will. If the Note 20 Ultra can only draw 25w, then that is what it'll do with a 45w charger. It'll only draw what it can.
    08-19-2020 12:57 AM
  17. evohicks's Avatar
    I'm happy with the 25 watt charger on the Note 10+ and to be fair I very rarely need the fast charge, that may change on the Note 20 ultra looking at some of the battery tests. I am currently testing the Huawei Mate XS and the charge on that thing is insane 55w charge!
    08-19-2020 01:15 AM
  18. j_hansen's Avatar
    I haven't seen more than 34w from the so-called 45w charger when testing it with my Note 10 plus 5G
    Of course I would like 120w fast charging but 25w works well enough that I never have *low power panic*
    Even charging overnight on the wireless I have disabled fast charge.
    08-19-2020 03:47 AM
  19. Mike Dee's Avatar
    120watt charging would kill the battery
    08-19-2020 12:52 PM
  20. ihbsbA's Avatar
    Where do we disable fast charge?
    08-19-2020 02:16 PM
  21. Mike Dee's Avatar
    It's in the settings....just search for charging or fast chargingNote 20 Ultra fast charging-screenshot_20200819-142439_device-20care.jpeg
    ihbsbA likes this.
    08-19-2020 02:25 PM
  22. james702283's Avatar
    It does support it actually Note 20 Ultra fast charging-screenshot_20200819-173705_google-20play-20store.jpeg
    08-19-2020 05:38 PM
  23. Jaycemiskel's Avatar
    I think devices that do 120W have split batteries in them that charge simultaneously at like 60W or something. If I could get that fast of charging I'd get it. Just would replace the battery every year. It only costs like a hundred bucks to do so.
    08-19-2020 09:15 PM
  24. mustang7757's Avatar
    It's in the settings....just search for charging or fast chargingClick image for larger version.
    So the 45w works ?
    08-19-2020 09:16 PM
  25. james702283's Avatar
    So the 45w works ?
    Yes, mine says super fast charging when connected to the 45 W charger with the correct type of cable. I think they ommitted it in the advertising because when the note 10 came out with it , most of the aftermarkwt cables couldnt support it so they probably had a lot of complaints from userw using the wrong cables and just left it out of advertising to avoid that again. Who knows. Definitely faster on the 45 watt tho.
    mustang7757 and Nostromo79 like this.
    08-20-2020 04:35 AM
85 123 ...
  1. Does a wireless charging dock exist?
    By roba5263 in forum Chargers and Batteries
    Last Post: 08-20-2020, 02:27 PM
  2. Marquise Brownlee reviews the Note 20 Ultra.
    By bold1193 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-19-2020, 12:43 PM
  3. Samsung Galaxy S20 Ultra unlocked I need WiFi calling
    By Cameron Rich1 in forum Ask a Question
    Last Post: 08-18-2020, 04:26 PM
  4. Got my Note 20 Ultra
    By Android Central Question in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-18-2020, 04:12 PM
  5. Replies: 2
    Last Post: 08-18-2020, 02:10 PM
