1. FredRickJames1970's Avatar
    Hi guys -
    I bought a Note 20 Ultra direct from Samsung for Tmobile...do you guys know if it comes with a Tmobile Sim or do I have to go and get one?
    Thank you!
    08-18-2020 03:08 PM
  2. hou33guy's Avatar
    Use the one thats in ur current note 10 if that applies
    08-18-2020 03:19 PM
  3. FredRickJames1970's Avatar
    I don't have a sim.
    08-18-2020 03:20 PM
  4. Deke218's Avatar
    Do you have a T-Mobile phone? Then again, if you purchased a T-Mobile branded Note 20, it should have a sim.
    08-18-2020 03:23 PM
  5. FredRickJames1970's Avatar
    I am coming from an Iphone on Tmobile...I do NOT have a physical sim in the iphone, I am using an electronic sim from Tmobile, which iphone has. If the new phone doesn't come with a Tmobile sim I will have to physically go to a store and get one instead of just calling and doing it over the phone. UNLESS the new Note allows electronic sims?
    08-18-2020 03:28 PM
  6. ZuperioKing's Avatar
    The Note 20 Ultra comes with eSim. How to enable it, you would have to contact T-mobile.
    08-18-2020 06:13 PM
  7. ihbsbA's Avatar
    How do E-sims work??
    08-18-2020 06:17 PM
  8. FredRickJames1970's Avatar
    On an iphone if you go under settings there is an IMEI for the phone then multiple electronic sim numbers that you give to your cellular carrier to activate...they then usually send you a barcode in an email that you scan which has your plan and information and then that is that, the phone will activate on that electronic sim.
    ihbsbA likes this.
    08-18-2020 06:39 PM
  9. airkorea08's Avatar
    Tmobile branded phones will have a sim in there that you can activate. Instructions are on the sleeve that the Sim card is in.
    08-18-2020 07:37 PM
  10. Deke218's Avatar
    That's incorrect. You need a physical sim card for a Samsung phone.
    08-19-2020 12:35 AM
  11. j_hansen's Avatar
    Some of the versions this year is supposed to have eSim.
    I think it's the HK version that has dual hybrid sd/sim plus also eSim so you could have sd card plus sim card and another number on eSim
    08-19-2020 02:13 AM
  12. bmetelsky's Avatar
    My order summary from VZW references a virtual sim. Can anyone enlighten me?
    bold1193 likes this.
    08-19-2020 07:24 AM
  13. NIZMOZ44's Avatar
    AT&T also provides a sim for the ones shipped from Samsung.
    Serkle K likes this.
    08-19-2020 10:17 AM
  14. ZuperioKing's Avatar
    This comes directly from Samsung press.
    “The eSIM functionality comes with all Samsung Galaxy Note 20 Ultra devices, excluding China, Japan, and Korea.”
    08-19-2020 10:22 AM
  1. How does Google know what I am watching on my TV?
    Last Post: 08-12-2021, 06:36 AM
  2. Does a wireless charging dock exist?
    By roba5263 in forum Chargers and Batteries
    Last Post: 08-20-2020, 01:27 PM
  3. Quear App on my UMX phone
    Last Post: 08-18-2020, 09:50 PM
  4. Samsung Galaxy S20 Ultra unlocked I need WiFi calling
    By Cameron Rich1 in forum Ask a Question
    Last Post: 08-18-2020, 03:26 PM
  5. Can I disable the temperature sensor of my Samsung A20 phone?
    Last Post: 08-18-2020, 12:39 PM
