when I receive a text message. Notification sound is turned all the way up. Any ideas how to get the sound to work?
Do you have a Bluetooth device hooked up to the phonewhen I receive a text message. Notification sound is turned all the way up. Any ideas how to get the sound to work?
You should be able to customize DND to allow notifications?I had apparently turned on do not disturb. Turning it off solved the issue.
