1. spinachie's Avatar
    Anyone else experiencing this?
    I have to swipe down a couple of times from the home screen before it registers properly.
    It's happened way too many times now for it to be used error.
    08-21-2020 04:48 PM
  2. spinachie's Avatar
    Just to add this seems an issue after performing any action to get back to the home screen. E. G I exit chrome and am on the home screen. It won't swipe right or left or bring down notifications for the first swipe. If I wait a few seconds it's fine, but if I do it straight away it takes two swipes. Is anyone else experiencing this?
    08-24-2020 02:23 AM
  3. pinkapple14325's Avatar
    I've not experienced any problems with it.
    08-24-2020 04:41 AM
  4. lindajm22's Avatar
    Mine is fine. Are you using a special launcher? Or maybe your case is getting in the way?
    08-24-2020 06:23 AM
  5. Lecrae116's Avatar
    Have you enabled this setting? If not ,Then that Setting should help You out
    08-24-2020 06:29 AM
  1. Replies: 9
    Last Post: 08-21-2020, 06:55 PM
  2. No notification sound
    By iontrap in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-21-2020, 06:05 PM
  3. Replies: 0
    Last Post: 08-21-2020, 02:25 PM
  4. Bixby routines for WIFI
    By jadenerd in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-21-2020, 01:21 PM
  5. Replies: 1
    Last Post: 08-21-2020, 02:00 AM
