10-15-2020 10:58 PM
57 123
tools
  1. BigMosley's Avatar
    Yeah fixed 96hz or 120 hz
    I'm only getting about 5.5 hours of screen on time anyway, so I'm going to lock down the 120hz and see if I get less than 5.5 hrs.
    Apple2Droid likes this.
    08-23-2020 04:10 PM
  2. mustang7757's Avatar
    I got 6.5 SOT but need to test it more
    08-23-2020 06:32 PM
  3. mustang7757's Avatar
    So wouldn't it kill more battery having it as fixed 96hz compared to adaptive from 1-120hz auto? I would think it wouldn't make a difference then.
    I'm still testing , not sure yet
    08-23-2020 06:48 PM
  4. jrcorwin's Avatar
    Hmm I don't see the point of doing this.
    08-24-2020 08:07 AM
  5. mustang7757's Avatar
    Its if you want it at 96hz /120hz all the time instead of the adaptive 120 which will change based on content
    08-24-2020 09:28 AM
  6. smooth4lyfe's Avatar
    Interesting. I'm gonna try this out and see
    mustang7757 likes this.
    08-24-2020 10:47 AM
  7. mustang7757's Avatar
    Definitely
    08-24-2020 10:48 AM
  8. johnsamuels's Avatar
    The thread at XDA has two comments suggesting that the 96mhz is variable, not fixed. I wonder if that's the case.
    08-24-2020 10:54 AM
  9. evohicks's Avatar
    A lot of phones are fixed at 90hz with no option to change, I can see this as a good option to be fair, but variable even better.
    08-24-2020 11:37 AM
  10. jimd1050's Avatar
    I just installed it and set it to 96... I'll see if battery life changes over the next few days! Not sure if I'd even notice yet because I'm not even sure if the thing has even adapted to me yet to begin with!
    08-27-2020 03:47 PM
  11. jadenerd's Avatar
    Will this let you run WQHD+ at 96hz?
    08-27-2020 04:16 PM
  12. jimd1050's Avatar
    No, see Ruben's Post Number 8...
    08-27-2020 04:32 PM
  13. Apple2Droid's Avatar
    Excellent question.
    08-27-2020 04:56 PM
  14. Ruben Ocasio's Avatar
    Excellent question.
    I answered this on post #8 which i answered no it won't, at least not yet if the developer finds a way i will post it here for now we can't run WQHD+ AT 96HZ OR 120HZ
    08-27-2020 05:10 PM
  15. DSMpowerhousegroup's Avatar
    Mine is as smooth as butter in adaptive. I don't think I need it. Software is doing a pretty good job with it on my device.
    j_hansen likes this.
    08-28-2020 11:01 PM
  16. AndroidFanboy8's Avatar
    Since installing this my device started over heating......did this happen to anyone else out there?
    09-12-2020 09:12 PM
  17. mib1800's Avatar
    My phone runs cooler after setting it to 96hz.
    I use the adb method to set max value so the VRR still works. Using the app will fixed to 96hz.
    Now I touch screen, it goes to 96hz. A moment later it drops back to 60. Playing yt, it drops to 48hz.
    09-12-2020 10:01 PM
  18. Hermes Hidayat's Avatar
    Why 96Hz? Why not 90Hz? Or 80Hz?
    10-07-2020 10:55 AM
  19. Hermes Hidayat's Avatar
    in order for it to work,you must set to Adaptive.then press the 96hz toggle.if set to 60hz,no matter how many times you press the 96hz toggle it wouldnt change.
    10-12-2020 11:52 PM
  20. mustang7757's Avatar
    I went back to adaptive how samsung has it , didn't notice anything different
    10-13-2020 12:14 AM
  21. Mike Dee's Avatar
    Did you try blinking rapidly?
    10-13-2020 12:42 AM
  22. mustang7757's Avatar
    Hahaha, No!
    10-13-2020 12:51 AM
  23. JellyBelly474's Avatar
    Can you please tell me how to set my phone to adaptive as I'm confused and don't understand? I have downloaded the app to my S20U Exynos but nothing changes but when I go into the app and click on 96hz. I'm using medium power saving.
    Note 20 Ultra has a secret 96hz display refresh rate - Here is how to enable it.-screenshot_20201015-224217_one-ui-home.jpgNote 20 Ultra has a secret 96hz display refresh rate - Here is how to enable it.-20201015_224426.jpgNote 20 Ultra has a secret 96hz display refresh rate - Here is how to enable it.-screenshot_20201015-225615_s20-refresh-rate-control.jpg
    10-15-2020 04:58 PM
  24. mustang7757's Avatar
Name:	Screenshot_20201015-224217_One UI Home.jpg
ID:	327823Click image for larger version.
ID:	327824Click image for larger version.
Name:	Screenshot_20201015-225615_S20 Refresh Rate Control.jpg
    Hi,
    Just uninstall the app and go into settings>display >motion smoothness leave in adaptive. Not any power save mode other then optimized or high performance will turn it off unless you go through bixby routines as there a thread for that .Note 20 Ultra has a secret 96hz display refresh rate - Here is how to enable it.-screenshot_20201015-183917_settings.jpeg
    JellyBelly474 likes this.
    10-15-2020 05:40 PM
  25. JellyBelly474's Avatar
    Hi,
    Just uninstall the app and go into settings>display >motion smoothness leave in adaptive. Not any power save mode other then optimized or high performance will turn it off unless you go through bixby routines as there a thread for that .Click image for larger version.
    Thank you mustang for your quick reply. I have looked at at my settings but I don't have adaptive, only high and standard. Don't know what to do. I'm back on optimised battery. I don't use Bixby routines.
    Note 20 Ultra has a secret 96hz display refresh rate - Here is how to enable it.-screenshot_20201015-234515_settings.jpg
    10-15-2020 05:48 PM
57 123
  1. How good is Samsung Internet?
    By BadingaG59 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-06-2020, 10:01 AM
  2. How to put external nfc on my phone
    Last Post: 08-28-2020, 09:25 PM
  3. Did anyone NOT get the Ultra?
    By klotsberg in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-28-2020, 05:31 PM
  4. Note 20 Ultra Samsung Coud
    By Leafs1201 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-28-2020, 02:46 PM
  5. [FREE][APP] Like Me Counter, Your Social Network Display
    By App Addict in forum Android Apps
    Last Post: 08-28-2020, 02:26 PM
