1. james702283's Avatar
    I'm I guess what they consider a power user. I take up a lot of storage, have always used the higgest capacity sd cards. Currently I am using the 512 GB Samsung Evo+ I got when it was released. I know Sandisk makes a 1TB, does anyone have any info on when Samsung will release their 1TB Evo+? While Sandisk is decent for file transfers I wouldn't rely on them as a primary sd card.
    08-25-2020 02:48 PM
  2. Talderon's Avatar
    Not sure what happened with you and SanDisk, but I have been using SanDisk for years and have not had any issues with them.
    08-25-2020 03:35 PM
  3. felloffthetruck's Avatar
    If they ever do release one I'm sure it start at $499. or more.
    The 1TB Sandisk is down to like $229.
    08-25-2020 03:53 PM
  4. j_hansen's Avatar
    Would one of the small Samsung SSD drives not suit you?
    08-25-2020 05:03 PM
  5. james702283's Avatar
    No, I have several of their ssd's, nvme drives and even the usb c flash drive. I want internal storage.
    08-25-2020 05:06 PM
  6. james702283's Avatar
    I used to use them religiously and then had two cards die on me in a short period of time. I have been using Samsungs evos since the 64gb was the highest capacity and I have had no issues at all so far. I'd just prefer to use them and am fine waiting with my 512 Samsung until they release a 1TB.
    08-25-2020 05:08 PM
  7. ladiinay's Avatar
    My SD Card is a SanDisk 1TB and I have had no issues. It's convenient for me because Iike the feeling of never having to worry about storage.
    felloffthetruck likes this.
    08-25-2020 10:40 PM
  1. Google Chrome / Samsung 9 / Lost Bookmark option?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 10-13-2020, 02:42 AM
  2. So Samsung Email app no longer comes loaded on the N20U??
    By donm527 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-24-2020, 10:28 AM
  3. SD Card useless now?
    By iFortWorth in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-03-2020, 06:01 AM
  4. Default notification sound permanently on in background on samsung A71
    Last Post: 08-25-2020, 12:21 AM
  5. 2021 Samsung S21 / Note 21
    By bkdodger2 in forum Rumored Devices Lounge
    Last Post: 08-24-2020, 10:50 PM
