1. Lecrae116's Avatar
    The button feels almost stuck inward. Anyone else had this problem?
    08-26-2020 08:35 PM
  2. mustang7757's Avatar
    08-26-2020 08:38 PM
  3. Lecrae116's Avatar
    Hi, with case on or off ?
    Both ways
    08-26-2020 08:39 PM
  4. mustang7757's Avatar
    Both ways
    Not having that issue, try cleaning it
    08-26-2020 08:40 PM
  5. Lecrae116's Avatar
    Any recommendations on how to do this?
    08-26-2020 08:42 PM
  6. o4liberty's Avatar
    My note 20 buttons are extremely tight actually hard to press at times. I would send your back.
    08-26-2020 08:46 PM
  7. mustang7757's Avatar
    I clean around the button with baby wipes or something similar
    08-26-2020 08:47 PM
  8. Lecrae116's Avatar
    So is mine. But my note 10 plus is easy as apple pie
    08-26-2020 08:48 PM
  9. Ruben Ocasio's Avatar
    Feels normal on my end just tried the Note10 Plus as well both feel the same to me. I see no issues here, can try cleaning it with a alcohol pad.
    08-26-2020 09:00 PM
  10. lyingfromyou's Avatar
    I wouldn't use gummy as the description.. Even with my OtterBox Defender the button is pretty sensitive. I haven't tried it without the case to see which is the culprit. Never had a phone with a power button so touchy though, wouldn't go as far to say it feels broke...
    08-27-2020 05:27 AM
  11. donm527's Avatar
    I forget without a case but with my Spigen Ultra Hybrid clear case it's got a nice satisfying click to it. Volume buttons to match. I would say all three buttons should feel the same.
    08-27-2020 06:59 AM
  12. Lecrae116's Avatar
    Volume buttons make an audible click. Even after cleaning power button with a baby wipe it still doesn't click and feels like its stuck inward.
    08-27-2020 08:59 AM
  13. mustang7757's Avatar
    As you get it moist the power button keep pushing it in and out until it feels free
    08-27-2020 09:06 AM
  1. Note 20 Ultra S-PEN Calibration[Solved]
    By sasha in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 10-20-2020, 02:08 PM
  2. long press home button for google assistant does not work
    By UNCMo96 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-31-2020, 08:06 PM
  3. Note 20 Ultra Shadow on White Screen ?
    By felloffthetruck in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-30-2020, 03:32 PM
  4. Aug 24 update breaks Samsung notes.
    By Thinair1911 in forum Samsung Galaxy Note 9
    Last Post: 08-28-2020, 02:13 PM
  5. Behold, the best Screen protector for the Note 20 Ultra.
    By Chris134 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-27-2020, 10:39 AM
