I'm a long time Nova Prime user and I love the launcher and it's options. I do, however, not see a way to do split-screen. Am I missing something or just being bone-headed?
Spite up and hold until apps come up, tap the icon, tap open in slot view, choose 2nd app. View attachment 325365
It shouldn't affect which launcher you are using, once you access the Recent apps the stock one (OneUI) takes control and the split screen should work.Thanks all. After trying One UI for a moment I realize that I've become way too spoiled by Nova and can't choose to switch to One UI. At some point perhaps I'll be able to do the split-screen while using Nova.
Thanks, I was being bone-headed. Mustang777 set me straight too.It shouldn't affect which launcher you are using, once you access the Recent apps the stock one (OneUI) takes control and the split screen should work.
Yeah something has changed. With my Note 10. I used to be able to long press an app in the recent app window and select split screen as an option. Now, see below, I get the error that I can't. Using Nova, just as I did with my N10
How do you change to see your recent apps in that format?Yeah something has changed. With my Note 10. I used to be able to long press an app in the recent app window and select split screen as an option. Now, see below, I get the error that I can't. Using Nova, just as I did with my N10
An app in the Samsung app store called Good Lock. After you install that, look for the plug in called Task Changer. In the options for that, there's several ways to setup one's recent apps.How do you change to see your recent apps in that format?
