1. silverfang77's Avatar
    Appeared after I set the battery mode to High Performance. Doesn't appear in glossaries.
    Thanks.
    08-28-2020 11:47 AM
  2. Bike Mi Vie's Avatar
    High battery drain.
    silverfang77 likes this.
    08-28-2020 11:56 AM
  3. silverfang77's Avatar
    Makes sense. Thanks.
    08-28-2020 11:57 AM
  4. LdotAdot13's Avatar
    Thanks. https://uploads.tapatalk-cdn.com/202...5f0c7ffd6f.jpg
    There's an icon in your drop down menu to turn on or off
    Attached Thumbnails Mysterious Battery Icon-screenshot_20200828-130609_android-central.jpg
    08-28-2020 02:06 PM
  5. goji26's Avatar
    It's your power mode. Mine does it when I put it in performance mode.
    08-28-2020 03:59 PM
  6. SwitchBoardDj's Avatar
    So basically this icon only comes on in High Performance mode and it indicates high battery drain?
    08-28-2020 05:31 PM
  7. silverfang77's Avatar
    Yes.
    08-28-2020 10:43 PM
  8. mustang7757's Avatar
    This is normal to alert you that your in different power mode.
    Laura Knotek likes this.
    08-28-2020 10:46 PM
  1. Replies: 9
    Last Post: 08-30-2020, 01:23 AM
  2. Confused by battery saving options
    By johnsamuels in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-29-2020, 03:30 AM
  3. Battery life
    By IMANUT46 in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 08-28-2020, 06:24 PM
  4. Why is my battery life low
    Last Post: 08-28-2020, 11:42 AM
  5. Replies: 3
    Last Post: 12-23-2016, 06:18 PM
