1. corvette72778's Avatar
    Anybody tested if turning 5G off will help battery life? Since the LTE is also on the same X55 modem chip as 5G which is separate from the Snapdragon 865+, I wouldn't think there wouldn't be much improvement in battery life if turning off 5G. What's your thoughts?
    08-29-2020 10:44 PM
  2. mustang7757's Avatar
    I tested it for couple days , didn't see much difference
    corvette72778 and bhatech like this.
    08-29-2020 10:51 PM
  3. akuma13's Avatar
    For me, significantly. Now I just switch to 5G if I think I can download something faster.
    corvette72778 likes this.
    08-29-2020 11:11 PM
  4. zorian99's Avatar
    how do you turn 5g off?
    08-30-2020 09:02 AM
  5. Notefan161's Avatar
    I turned it off as my sim won't let me use 5G this year
    08-30-2020 09:15 AM
  6. evohicks's Avatar
    Same here, no 5g yet.
    08-30-2020 09:31 AM
  7. corvette72778's Avatar
    Under settings, connections, mobile networks
    08-30-2020 09:46 AM
  8. iFortWorth's Avatar
    With ATT one doesn't seem to have that option. It's all or nothing apparently.
    08-30-2020 10:26 AM
  9. TMavC5's Avatar
    Like any band, if your network constantly searching for coverage. This will drain your battery.
    bhatech likes this.
    08-30-2020 11:28 AM
  10. lindajm22's Avatar
    This is what I have under networks. What is Global? I live in a state that has zero Verizon 5G so I don't want it always searching.
    08-30-2020 11:50 AM
  11. zorian99's Avatar
    mine same...no 5g option just global and lte...must be because of Verizon
    08-30-2020 12:04 PM
  12. Kizzy Catwoman's Avatar
    Change it to LTE CDMA option
    08-30-2020 12:06 PM
  13. PAC757's Avatar
    Oh, I wish I saw this post before I ordered the AT&T version, would have went with the unlocked version. But I think soon as you put in an AT&T sim card you end up with the usual AT&T limitations. Any on AT&T find a way to turn off 5G?
    08-30-2020 07:15 PM
  14. kide#WN's Avatar
    I have the unlocked Note 20 Ultra on AT&T. No option to turned 5G off, same as on the AT&T-locked version.
    PAC757 likes this.
    08-30-2020 07:21 PM
  15. PAC757's Avatar
    That is what I thought would be the case with an AT&T SIM card in it, thanks for the info.
    08-30-2020 09:00 PM
  16. Illuminated_One's Avatar
    You've got go he kidding me!!!
    Seriously?? There has to be a way.... where can we complain about this to ATT?
    08-30-2020 09:08 PM
  17. iFortWorth's Avatar
    Not trying to be an ***.
    But do you honestly think ATT would give 2 craps?
    bhatech likes this.
    08-30-2020 09:31 PM
  18. castone001's Avatar
    I'll try this and see if my battery life improves. I'm not in a 5g area 90%of the time.
    08-31-2020 01:31 AM
  19. bandofbrothers2112's Avatar
    I've turned mine to Lte/3G/2G as I can't get 5G with my carrier in the Uk as I'm a Pay As You Go user i.e prepay so there's little point my phone searching for 5G and using any resources to do so.
    For me 5G just helps to future proof my phone if and when i can access 5G and if I want to download files faster which to be honest I don't do now anyway.
    08-31-2020 01:41 AM
  20. bhatech's Avatar
    Personally don't think it'll affect keeping in the default network mode. If there isn't any 5g connection then it's going to connect to LTE. It's not like it's constantly searching for 5g network. It'll connect to a tower and if it's 5G enabled or whatever then it'll use the 5G mode. I think it's placebo if you are thinking changing network mode is going to help. On the other hand if you are signal/network is generally bad that may affect battery life but not 5G itself and even if it'll it's going to be negligible.
    j_hansen likes this.
    08-31-2020 02:14 AM
  1. 'Network permission' notifications for apps in Android 10 - turning off
    Last Post: 09-06-2020, 01:02 AM
  2. Battery Capacity
    By croth56 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-31-2020, 10:14 AM
  3. Replies: 16
    Last Post: 08-30-2020, 02:13 PM
  4. Why does my phone have no sound at all.
    Last Post: 08-29-2020, 01:55 PM
  5. What does this icon mean ?
    Last Post: 08-29-2020, 01:06 PM
