We in 2020 got everything coveredThat's only if you can actually decipher what you wrote. Samsung needs to add a stang translator option.
How many of you use the spen in Samsung keyboard?
I use it sometimes, it's not bad.I never do. I honestly forget that it's an option.
I just use the spen sometimes to swipe on the keyboard instead of using the finger.I never do. I honestly forget that it's an option.
That's an impressive responseThat's only if you can actually decipher what you wrote. Samsung needs to add a stang translator option.
If I already have the Spen out is when I'm most likely to use it on the keyboard.I use it sometimes, it's not bad.
You get impressed easily!That's an impressive response
Good point while having it out!If I already have the Spen out is when I'm most likely to use it on the keyboard.
The Spen makes me sometimes feel like I'm using a Palm Pilot. Remember the crazy shorthand you had to learn if you had one?
Yeah, it's pretty cool!I didn't even know the Samsung keyboard had that handwriting feature. I would use that. But I can't seem to pull away from my Blackberry keyboard long enough! I need Samsung to offer swipe word delete (up to four words at a time) and long press letters for capitals. I just can't seem to give those two things up.
I think you have to sideload itHow do you install the Blackberry keyboard? I can't find it in the Playstore.
You know any links?Think it's part of Blackberry Hub app as well.
You know any links?
I remember reading from some members here that it was some type of sideload you had to do, was little obstacle to go through.It's in the Play Store. Requires a subscription to Blackberry services if I remember correctly.
