09-09-2020 02:45 PM
38 12
tools
  1. bkdodger2's Avatar
    I refuse to give a carrier upgrade fees..you not doing a thing I can’t do myself
    bhatech likes this.
    09-03-2020 02:22 PM
  2. cardboard60's Avatar
    Nothing to do with upgrade fees.
    I don't even want a unlocked phone from a carrier.
    09-03-2020 02:39 PM
  3. o4liberty's Avatar
    I always call a few weeks later and get a credit for these fees I feel the same way plus I always order online because store purchases can't be credited back.
    bkdodger2 likes this.
    09-03-2020 02:42 PM
  4. bhatech's Avatar
    Any carrier phone can be sim unlocked but still running crappy carrier firmware, only thing it can be used on any carrier after sim unlock.
    The reason I buy US unlocked model is not that because I can use on any carrier, but it's because it runs clean firmware as Samsung intended. If only SIM unlocking was important then I would gladly buy a carrier model since SIM unlocking them is straight forward.
    J Dubbs likes this.
    09-03-2020 03:11 PM
  5. bkdodger2's Avatar
    That's not bad as long they credit back ... It's crazy ... First they never offer any good deals for upgrades only once in awhile ... I know you need to entice new customers but take care those with you ....
    J Dubbs likes this.
    09-03-2020 03:23 PM
  6. ROE_HUNTER's Avatar
    I forgot about the upgrade fee, makes me even more happy I ordered unlocked from Samsung direct.
    bkdodger2 and larry1014 like this.
    09-03-2020 03:31 PM
  7. simplepink's Avatar
    You ask carriers they will say bull**** like that. Personally I haven’t had any issues and don’t think there is any difference. There may be difference in the way signal bars are represented on the UI like may be carrier firmwares show more bars than us unlocked or stuff like that. I’m sure some one here will say i had better this or that on carrier model vs unlocked. But personally IMO i don’t think there is any in terms of call, data speed performance. In terms of certain carrier features available on Unlocked models that varies from from carrier to carrier (looking at you crappy AT&T).
    But at the end to me there isn’t anything deal breaker that will have me even consider the carrier model over unlocked model. NEVER
    Thanks for being the only one to reply and help me out with this question! I have an unlocked device I purchased from Samsung and every time I have data speeds and call quality issues with any carrier, I'm being told that it might be because of my unlocked device which isn't a carrier version to give it the most optimal service performance and quality. They say carrier devices are set up and made to work on the carrier network at the best performance possible. Having unlocked could be reason why performance isn't the same but that seems all BS to discourage customers so they buy into carrier devices.
    I care about call quality and service/data performance. If there is no impact on service among any carrier on unlocked devices, I rather continue buying unlocked!
    ROE_HUNTER likes this.
    09-04-2020 10:25 AM
  8. simplepink's Avatar
    So now there is a difference among carrier unlocked devices and manufacturer unlocked devices?! What!!
    It seems from replies, it only has to do with the SMS?
    Good point about the cleaner firmware when getting directly from manufacturer. There's no tampering from the carrier.
    09-04-2020 10:29 AM
  9. cardboard60's Avatar
    Why is it the universal unlocked models are the ones that hasn't been running hot when charging.
    My buddy is on T-Mobile.
    He said he can be sitting right under a 5g tmobile tower on top of a telephone pole.
    And don't have a strong signal.
    T-Mobile don't have strong signals..
    My son is on tmobile.
    He has a iphone.
    He said you either have service, or you don't.
    Somebody on here has to have a T-Mobile carrier locked phone.
    Ask them how strong their phone is everywhere.
    09-04-2020 12:39 PM
  10. cardboard60's Avatar
    T-Mobile customers.
    Go to a T-Mobile store.
    Get T-Mobile to show you the 5G speeds they are supposed to have.
    Find out where the speeds exist.
    09-04-2020 01:57 PM
  11. cardboard60's Avatar
    T-Mobile is 2 people on 2 lines for 70.00 a month.
    If you find a place that you get good 5G service.
    You was very lucky.
    09-04-2020 02:26 PM
  12. ROE_HUNTER's Avatar
    I have a question to add to this thread. I am an ATT customer with Unlimited Plan which includes 30GB Hotspot which I do use. Will the Hotspot work on the unlocked Z Fold 2 I ordered?
    09-08-2020 05:56 PM
  13. bbgpsuser's Avatar
    That should work without any issue.
    09-09-2020 02:45 PM
38 12
  1. S20+ vs S20 Ultra vs Note 20 Ultra (Camera questions)
    By danicell in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 09-01-2020, 06:32 PM
  2. Time and date
    By Dale 1977 in forum Ask a Question
    Last Post: 09-01-2020, 11:36 AM
  3. Replies: 1
    Last Post: 09-01-2020, 11:33 AM
  4. Replies: 0
    Last Post: 09-01-2020, 04:51 AM
  5. Replies: 0
    Last Post: 09-01-2020, 04:49 AM
